Unknown electrical connectors
Welcome!!!!! DM me as soon as you are set up and ready to sell one of your wire kits.
I ordered PC3Z-5806200-B, $25.21 as of January 2025.
If you do not might me asking, where did you order it and I am assuming it was OEM or not?
Checked my 24 F350 this afternoon and the glovebox does not have the dampener. When you open it, it just drops. So I am going to order the dampener. I also contacted NEOHIO to purchase his cable he makes to get the benefit of those live 12V connections.
Just received the wiring harness in the mail today. I am posting an update because I am highly impressed in the quality.
I appreciate you waiting the week while I was away. Post some install pics when you are done.
I too received my cable from NEOHIO yesterday and it is very well done. See the pics I took of it below. It will be a while before I can get to installing it where I want and how I want. I want to put a fuse box in place to hook it into etc. I got one wire loom short for in the front of the cab under the glove box and then I had the extra length put on the other lead so I can run it to the back of the cab where I will place an additional fuse box. Very well done. The 12 V wires have shrink wrap on the end and the ground is available next to it. If you have the available connector under your glove box this is really an excellent connector for giving you 12 V on all the time. This along with the wire group that goes through to the engine bay give some real possibilities. I want to do the high idle mod and I want to use the power under the glove box to power my new Wolfbox Dash camera system as well as put in a USB for the dash where I will be installing my Bullet Point system. I need some warm weather and time which is always at a premium. I have my factory Warn winch to install, my new Baja LP4 A pillar lights and the Trailguard with lights and also I want to purchase and install some back up lights and I really like the BMC kit. Lots to do. Thanks NEOHIO for this cable. Nice job.
I'll take one, too :cool:
Great work again! I tried installing it this weekend but ran into the road block of where I wanted to put the recipient USB-C plug. I thought that Id be able to access the console cubby from the glove box being removed. I asked on anther thread but didn't get any response. Maybe more luck here? Anyone know how to get behind or gain access to this area without removing the entire dash or console? I'm afraid to make a hole not knowing what is behind there.
Try searching the forum for "console swap".
Might find threads on console to jumpseat conversions. Might be able to see pics from there.
Thanks for the advice! I found a few YT vides that show the swap and its really doesn't look like there is anything back there since the console is a totally separate bolt-in option. Essentially devoid of wiring and other important obstacles. I also went on Ebay and looked for center consoles and found a 2024 which has a lot of pictures. I am pretty confident I can drill away without worry of hitting any thing important. You can see the image below shows the driver's side USB plugs and the passenger side looks barren of obstacles. I might be able to fish the wires along the green route to the glovebox. May have a glass of bourbon first to settle the nerves.
Nevermind, now I have to think of how I would secure the outlet. I may have to find a outlet that pops in and not have a large nut on the back.
I added an outlet with screw back in the location you're showing. I was able to snake my hand back there by popping off passenger side console trim panel. No tools needed, just a bunch of clips holding it in place. Pain in the butt, but I was able to get it done.
Alternatively, IIRC it only seven screws and 4 connectors to completely free the console where you can slide it rearward and have space to your hearts content. Two connectors are on the floor between the console and passenger seat, and the other two are in the front of the console and become accessible once you slide the console rearward a few inches.
I ordered one of these (way overpriced for what it is) but it looks like a pop-in friction fit option. But I am definitely going to attempt to squirrel my hand back in there to see if I can do what you did. Id rather use the $16 plug than the $145 plug that has a parasitic LED light.
Memory is coming back now.
Once you pop off the panel secured with clips, the next thing you will find is the panel that the first one clips to. It is secured by a few screws that run longitudinally along the console. Remove the first two or three And then the front part of that panel will deflect enough that you might be able to get your hand in there. It was enough for me, but I’m that generic abnormality with small hands and a giant…..
