Tremor Wheel weight & offset
With only being 8 inches wide can these rims still be used with most of the 35x12.5x18 tires?? Most of the ones I have looked at show a range of 9.5-11 inches wide. I like these rims but plan to change to a Nitto Ridge grappler I have. I was told do not mount them on an 8inch rim. If not does anyone know a tire that is 35x12.5x18 that can go onto a 8inch rim? cheers
toyo does recommend a 8.5 wide fir 35.12.50 tires...you could run a 295.70.18 they are about .5in smaller, but .5in wider than the stock size, and they will fit on factory rims
My 7.3L is on order...not sure ETA based on COVID. That said, I want to flush the wheels but don't want to lift the truck. Anyone know if I'll have to trim anything if I use spacers?
looks like its .75 in out going from 40 to 20
so 6.57 backspace to 5.79 in backspace
Yes That whole website is Fantastic........great tools for wheels and tires.....found the offset tool last night......really cool.
I know this is an old thread, but does anyone know the weight of the Tremor wheel and tire combined? I saw 60 lbs for the tire, but never saw a reply saying how much the wheel itself weighs. Someone guessed it was 100 lbs for both, but I am looking for the real weight so I can compare it to my wheel and tire choices.
In case someone is looking for the weight information in the future, I found an article where the author weighs the factory Tremor wheels and tires at 89 lbs. If the Duratrac tires are 60 lbs, this makes the factory wheels a very light 29lbs. Some of the aftermarket 37” tires I am considering are 80+ lbs on their own... :oops:
Tremor Suspension - Autoblog
Discount says the Duratrac tire weighs 65 pounds...So that'd make the wheel 24 pounds???? Yeah no, like you said I'm inclined to believe it is closer to 30, although the wheel is only 8" wide. So a wheel and tire upgrade is going to make everything heavier at every corner. The combo I was looking at would weigh in at 99 pounds! Man...
I am not sure why Goodyear does not provide the weight of the tire on their own website like ALL the other tire companies... :mad:
This site lists the weight at 60 lbs, but as you found, other sites show different weight for the same tire.
Goodyear Duratrac
So for anyone who might be curious, I got my Ridge Grapplers installed today (35x12.50 R18), and just as I suspected, the overall height is pretty much identical to the stock Duratracs. Which to me is good news as there should be no issues with running the factory spare temporarily, of course. I have attached a couple of pics below to show.
Eventually I will be getting a fifth Method wheel to mount the spare tire to, but for the time being, it works.
View attachment 10328View attachment 10329
How do the Ridge Grapplers sound on the road? I really like the look of the tread...
I ordered the 37x12.5x17s for mine because I read they were much quieter than the Toyos and other 37" options.
Also, do you have any picture of the whole truck?
They sounded very quiet on the ride home. I just got them on this evening and didn’t get a picture of the whole truck with them on. I’ll take one in the morning daylight & post up tomorrow.
p.s. I wasted my daylight taking pictures of the old tires to post up for sale on the classified section of the forum. Sorry ?
The Tremor OEM tires are not typical 35X12.5, but are actually
285/75R18 that run more than an inch narrower. This is how the OEM fits on a 8 inch rim.
Here’s a few quick pics I took this morning when I got to work.
The wheels and tires look great! I like the blackout items you did to your badges and door handles, as well...
Are those capless 18x9 Methods with a zero offset? They look very close to being even with the fender lips.
@danthat looks great! Those tires, do you have the load index and speed rating by chance? Where did you get them at 12.5" wide??
Looks awesome, was thinking about that look myself but with 11.5" or 12" tires.
They came with caps but I just chose not to run them. They are 18x9 but they are a +18 offset. They are pretty much even with the fender on the rear.
They seem to poke out a bit on the front but I think it’s because the front part of the front fender has an aggressive inward curve. But I am VERY HAPPY with the stance and they way these tires feel while driving. And they are quieter than the Duratracs!
Thanks man, I appreciate it. I thought about which tires, M/T vs. AT vs. a hybrid and I debated over which brand and which size to go with for about a month.
I finally decided that this would work best for me with my wheels and my driving situation. So, I got the stats straight from the Nitto homepage for you.
Excellent, not much of a sacrifice in terms of Load Index rating...still speed rated for 100mph? Appreciate the feedback.
Where did you get the tires, I don't believe Discount has them in that width. They have them in 325mm width but that's like 12.79inches and they're 127Q. It's not sacrificing much, but too wide.
I’m surprised that Discount Tire either doesn’t have them or can’t order them for you as that’s an extremely popular size. I got them from a locally owned tire shop called Tire Link. They only have 3 stores here in town but they compete directly w/ Discount Tire on price and on service. They won me over as I had been shopping at DT for over 30 years now, but I gave these guys a shot, & they gave me a killer deal on my Method Wheels.
Oh, and the “Q” means that they are speed rated for 99 mph, which is the same speed rating as the Stock Goodyear Duratracs.
True, the ones I looked at were rated for that speed but they're slightly lower in the load index vs the tires you got which are 315/12.5".
That's cool that you have stores that compete with Discount, I can't think of many if any here in my town...Perhaps a local truck shop may be able to help. Actually they would, they sell tires and provide balancing but I'm not sure its free like Discount after a purchase.
