- OP 🔹
- #41
Oh yes I forgot about those, I do like them but not for thousands haha.Also an extremely minor difference, but I like the subtle fender flares the Tremor comes with.
I just built both online: optioned up the exact same as my FX4 with BAP, 7.3L, locking rear, heated wheel and rear seats, Lariat Value, 5th wheel, tailgate step.I guess a couple general points.
1. Ford build and price tool sucks. Use the one on Nada Guides, it is historically far less error prone and also shows you MSRP and Invoice pricing for everything.
2. The FX4 package is heinously overpriced for what you get. You are forced into buying a ton of individual options when you opt for that package. The cost of which is not reflected in the FX4 package price. The FX4 shocks are garbage. You are better off individually adding the rear locker, AT tires, and skid plates. You can add hill descent to any non-Tremor with a $15 switch and 5 minutes in FORSCAN.
If you don't believe me check yourself. But the FX4 package lists at $400. However you have another $2k in mandatory additions.
Just curious if you also chose the 4.30 e-locker with the FX4?I just built both online: optioned up the exact same as my FX4 with BAP, 7.3L, locking rear, heated wheel and rear seats, Lariat Value, 5th wheel, tailgate step.
Tremor was $69980
FX4 was $67,365
Difference of $2,615
Not really sure how you came up with your numbers!?
I just did on the configurator not 10 minutes ago. I personally went with the 3.55 when I ordered, but, they are the EXACT same price for either gearing.Just curious if you also chose the 4.30 e-locker with the FX4?
My changed order is a Lariat with FX4 and 18s. Selecting 18” ATs before or after the FX4 package works.On the FX4 thing I believe he was pointing out by selecting that it adds that package, plus electronic locker, plus changes to 20" wheels so its a $2k+ swing in pricing IF you didn't already have the locker selected and 20" wheels on your build (which I did already). If you just want 4x4 with 18" wheels for less cost don't select FX4, just add the skid plates seperately and electronic locker if desired.
IF you have electronic locker and 20" wheels already and just want the skid plates but don't care about the shocks/hill control then you can add those for $100 rather than $400.
Its weird in that it initially forces 20's but you can select back to 18s it appears.My changed order is a Lariat with FX4 and 18s. Selecting 18” ATs before or after the FX4 package works.
good luck getting a truck built with 5th wheel prep and the black package due to the spray in bed liner.
Those are 2 of the leading constraints.
I would not order the hood deflector either. Get it after the fact with Ford Pass points.
then it seems like your mind is made up and you shouldn't get a tremor.FX4 issue: For $400 you get skid plates, a sticker, shocks, hill decent control. If you are inclined you can get just the skid plates for $100 and add the hill descent control afterwards for ~$20 plus a quick forscan mod. That leaves ~$280 on the table to buy better shocks than the FX4.
My build baseline. Pick either a F250 or F350, it doesn't matter in terms of costing, black appearance, 7.3 4x4 with 4.3 locking rear and skid plates as a baseline. Add tremor and it costs ~$2900 more which is huge considering it brings minimal value to the table for me. IF picking FX4 instead then its ~$2600 difference, see above what you get for that $300 I'd rather spend after market.
I'm not in a hurry to be honest, I just want to mentally decide on it and lock in pricing sooner than later. This is just a planned replacement of my current truck that could happen now or next year frankly.
Noted on the deflector suggestion.
Yeah at this point I believe its the wrong fit. I really was making sure I wasn't overlooking what the option offered or how the option selections interacted, etc. I just can't wrap my head around where the $2900 in value difference is for the front limited slip, different shocks, fender flares, 35" duratracs vs 34" michalin, 18" rims vs 20" rims both black, tremor running boards vs black appearance running boards.then it seems like your mind is made up and you shouldn't get a tremor.
-I dont think the Ultimate package is worth it really over the Value, but I WANTED the LED's
I mean the value is there since you have to get something from the factory, and if you replace those items it’s going to cost way more than the 2900 differential between parts and labor unless you’re thrifty with selling the stock parts and perform the installations yourselfYeah at this point I believe its the wrong fit. I really was making sure I wasn't overlooking what the option offered or how the option selections interacted, etc. I just can't wrap my head around where the $2900 in value difference is for the front limited slip, different shocks, fender flares, 35" duratracs vs 34" michalin, 18" rims vs 20" rims both black, tremor running boards vs black appearance running boards.
REALLY seems like they are missing some deducts that should be involved in combining tremor and black appearance.
I can’t see the limited slip up front after market coming in less than 1k from a shop with labor and it’s no longer under warrantee
For LEDs you could get after market lights for $1200-1600, that is one value route I’m planning personally
Plus in normal times the difference in package price would be negotiated away mostly. It’s just a crazy time where people are actually paying MSRPs on these things
