Tremor not worth it in my case?
Im actually debating this now. I have a ‘21 F250 tremor now. I priced a loaded 2022 F250 tremor with ultimate, black appearance w/o panoramic roof with a loaded 2022 F250 platinum FX4 w/o a panoramic roof. Both $67k through granger. I was debating swapping out the shocks on mine right now. So if I’m going to do that then the platinum makes sense. A little extra payload in the non tremor as well.
I'm not sure what packages you're building. I built an FX4 and Tremor. Price difference was marginal and within $300 i believe
FX4 issue: For $400 you get skid plates, a sticker, shocks, hill decent control. If you are inclined you can get just the skid plates for $100 and add the hill descent control afterwards for ~$20 plus a quick forscan mod. That leaves ~$280 on the table to buy better shocks than the FX4.
My build baseline. Pick either a F250 or F350, it doesn't matter in terms of costing, black appearance, 7.3 4x4 with 4.3 locking rear and skid plates as a baseline. Add tremor and it costs ~$2900 more which is huge considering it brings minimal value to the table for me. IF picking FX4 instead then its ~$2600 difference, see above what you get for that $300 I'd rather spend after market.
I initially ordered a Tremor. Lots of internal debate, but said screw-it. Then I got another trailer, that ended up being pretty heavy on the pin and limited tailgate clearance. So after a lot more debate and questioning, went back last week and changed to the CCLB SRW that had been my initial comparison. Maxing out payload, more front bed room, bigger fuel tank for the 7.3, and lower bed height were my driving factors at the end.
I originally had a F350 FX4 spec'd and ordered and then changed to an F250 Tremor for the following reasons:
1) I discovered that there is no functional difference between an F350 Tremor and F250 Tremor
2) People that I personally spoke with that had driven/ridden in both a Tremor and non Tremor stated the ride was better in a Tremor (still a SD, though, so not night and day)
3) Legal capacities worked in my favor for my usage (10k GVWR, 2720 payload, 15K towing, 24.9K GCWR)
4) I love the way it looks!
Going from a Blk Pkg F350 FX4 to a F250 Tremor lowered the final price slightly. I did purchase as an A-Plan so I can't say if that factored in or not... I wouldn't think so... Dropping the black package contributed somewhat but I did add back in the LEDs, wheel well liners, and spray in bedliner that are included in that package.
Lots of discussions on this, but functionally there is no capability difference between the two, just a one digit difference in the badges and the legal capacity if you need it... that was the catalyst that started it for me.
Correct a sticker issue if F250 tremor vs F350 non, but in my case still costs more for the F250 tremor apples to apples (black appearance on both, 4x4, 7.3L, 4.3 rear and skid plates).
2) I'm curious on that point, the rear springs are standard F350. Is the better ride in the taller tire walls (18" vs 20"), front springs, and/or shocks? The shocks can be addressed if so. I have been searching HARD to try and find clarification on why the tremor would run smoother.
I think that the Tremor package is best suited for people (like myself) that want to buy a truck and not monkey around with it much. I will not be lifting, leveling, Carli adding, etc. I just want to buy my truck and enjoy it. The SD Tremor package is really pretty sweet for a OEM setup. It has all of the things added that I would like to do to a normal SD, but probably wouldn’t take the time or money to do. If you plan to change everything anyway, then no it doesn’t make any sense at all. If a regular SD is a better fit for your needs then it also wouldn’t make any sense to go with a Tremor. When buying a truck this expensive 2-3k or 2-3 mpg really shouldn’t make that much difference in the decision making. Get what you really want.
I don't plan to mod it all. A standard 4x4 with skid plates, rear locker, and a 34" tire should serve me just fine. There are a couple things appealing still on the tremor but not for $2900 and also less efficient tires that I'm now to understand aren't even snow rated. If I could add the front limited slip separately (from factory) and switch running boards/air damn on my build there would be zero debate in my head that I'd just order a non-tremor. With the way I configured my build its basically charging me $2000k for the 35" duratracs versus the 34" all terrains best I can tell.
I just don’t want the tremor without the black appearance package. Adding it will make you wait 6-8 months for it. I don’t know why you can’t delete the bed liner from it. If you’re waiting 8 months you might as well get a ‘23.
*Air damn looks way better on the tremor but that’s cheap after market - $100ish value
This can be achieved but just cutting the one that comes on it down. I know of a few dealers who do it already when they add wheels and what not and have a friend who did it on his F350 after he saw my tremor.
Just a side note
Just a side note
I figured as much, but wanted to put a value on it if doing a factory one.
Yep totally agree. Changing to Star White was lumped into my change progression too. With that color I preferred the chrome and non-black accents, but still wanted the black wheels. The difference between that full package and the a la carte options + the ~$800 or so between F350 and F250 is what offset the increased cost due to the Tremor pkg.
I think the shock tuning + the increased sidewall with the 18" rim/tire combo is what contributes the most, but that is just speculation on my part. It would be interesting to get someone's feedback that has purchased Tremor wheels/tires and put them on a non-Tremor SD.
At this point the constant price increases have me concerned about that. Heck if I option enough things maybe it ends up being a 23' in the end haha
I guess a couple general points.
1. Ford build and price tool sucks. Use the one on Nada Guides, it is historically far less error prone and also shows you MSRP and Invoice pricing for everything.
2. The FX4 package is heinously overpriced for what you get. You are forced into buying a ton of individual options when you opt for that package. The cost of which is not reflected in the FX4 package price. The FX4 shocks are garbage. You are better off individually adding the rear locker, AT tires, and skid plates. You can add hill descent to any non-Tremor with a $15 switch and 5 minutes in FORSCAN.
If you don't believe me check yourself. But the FX4 package lists at $400. However you have another $2k in mandatory additions.
I touched on that already (thanks to my reading on here!) :)
What are you seeing for highway RPMs and MPGs with the 3.73s and the modification to the tremor front air damn? This would be very useful to my decision making.
I get high 13's around town, high 16's on the highway over a few hundred miles.
I have the MBRP exhaust as well, and at cruise it's a barely audible rumble in 10th. Towing the exhaust is a little barky in 8th when climbing, but I'm usually in 9th on the highway with my 8000lb travel trailer.
Thats with the air damn mod? If so sounds like the tires/gears (you decide how much for each) is about 2mpg better than what I've been seeing for the tremors tires/gears.
35" off-road tires. Doesn't have to be mud tires, any off-road tire is going to have high rolling resistance and 35" is going to add weight. It may not seem like much because you're talking about a HD truck but rotating mass is much different than vehicle mass.
If you don't want 35" tires -- you don't need Tremor. Most of the things Tremor gives you is around that. You have some menu screens, as I understand it, that are Tremor exclusive . I won't get into the real-world usefulness of those as everyone has an opinion on them.
So with Tremor you get a lift and everything to run 35" tires that you need. The cost is a lot less than you'd spend having someone else do it after the fact. Might be able to do it yourself for similar cost or maybe even less -- but that's just the suspension aspect.
Since you're talking about going with the 7.3 -- if you ever went 35's with 3.73 gears you'd likely end up regretting that gearing. As far as I know you can get 4.3 on a truck without the Tremor -- if that's true you could just choose that. I say likely because who knows -- maybe it wouldn't bother you. I know it would bother me -- but that's just me.
That's my opinion, anyway. It basically comes down to 35's or not. If you don't want to run 35's -- I would say the Tremor is not the right investment. You'd certainly save a lot on fuel economy. The difference in fuel economy between nitto grappler's and duratracs is negligable, though. You're talking maybe tenths of a MPG or a MPG. The difference between mud tires like the duratracs and 33" street tires is probably 3-5 MPG highway. Mind you, this is on a GAS truck only -- diesels don't hardly flinch at mud tires. My son ran 37" super swampers for years and got over 20MPG in his 2018 ram -- which was basically the same as he got when he had the factory tires on it with no lift. Gassers are just more sensitive to wind and rolling resistance.
Yes I can get the non-tremor with 4.3 gears and 34.1" all terrains as an option. Also can get it with 3.73 in the F350 lineup. Both with electronic lockers.
