Tremor Engine 2nd guessing myself
Talk about irony... Just got an email from the dealer saying the truck has been scheduled for build, too late to change. Oh well, I was still on the fence either way. I'll get the 7.3L and see how I like it. If it doesn't work out I can always trade it in on the 6.7 later on.
Hopefully the crazy values hold for you if you choose to change. I will say the 7.3L is plenty capable of pulling a 15K horse trailer. My coworker does it with a 6.2L CCLB with the 3:73 gears here western MT. At that weight the gasser will pull just fine but the 6.7L is not even breaking a sweat.
@ZipperMerge583 - why is a 7.3 better for hunting and off-road, in your opinion?
I tried to understand your thoughts and took the following line:
1) Cold weather with lack of plug in options?
2) Heavy weight in the front with the diesel?
3) Noises that frighten game and other hunters?
curious…
I do hunt and travel off-road. I also have horses. I also have driving styles / situations with short runs, but I never questioned not going with the 6.7. To me I’m an over preparing type when I buy quality items. I go with the “may need” rather than “wish I had” rule.
The weight of it sucks especially in the snow any kind of sidehill it kinda goes where it wants, that was all i ever noticed, and cold weather, but the rapid cabin heater in these makes it pretty nice in the cab at least. Short trips in my 07 dodge sucked cuz it would never get warm enough. My 2020 diesel sat out side when it was 25 below last year and started right up no issues, and only like a 2-3 second delay, only put in fuel additive once, may have just gotten lucky on that end with no gelling
At least now you can try the 7.3 and if you like it that does save you $8k. Hope it comes in soon for ya, good luck.
Adding: That weight is at the conventional towing limit of the platform.
I regularly tow 15k over a mountain and the 7.3L has no problem going up and no problem engine braking the whole way down.
Unless you define consuming a half a tank of gas in the process as a problem.
Noting too: Part of the appeal of the 7.3L, IMO, is that it acts like it’s working. e.g. It likes to produce power at 4K RPM. It will stay near there in tow mode with or without a load. And the motor loves to growl. I view that as a feature, by design. The first time I towed a few thousand pounds I thought it meant the engine was having to work for it. And then I realized it behaves the same no matter how much I’m towing.
And above 10,000# in this truck you start to realize how unoptimized the Tremor is for heavy towing from a tire, brake, and suspension perspective. Further cementing the fact that the motor is far from a limiting factor on these trucks.
I used to have an Isuzu NPR HD dump truck.
It had a 5.2L 4-cylinder motor producing 215 HP and 452 LB-FT of torque. (May have even been slightly less power as these are current model year numbers.)
I towed about 16000# with it every day. Often with a couple thousand pounds of dirt/rock in the bed. And it had a 8000# curb weight.
If I had that truck still, I’d use it for towing over the Tremor every time despite being woefully underpowered as compared to any Ford motor.
Why? Because the power was plenty sufficient up to the 26000# GCWR.
And that thing handled and stopped like a dream when loaded as compared to the Tremor which is an overpowered medium-duty platform.
So again, the decision between these motors has nothing to do with capability. That’s fact. It just comes down to:
Cost
Fuel Mileage
Everyday Use Case
and Penis Size
Many rational arguments for gas or diesel preference on each axis. But the last one trumps them all. If you have a small penis your truck better have all the torque you can buy.
I'm excited to get the 7.3 and give it a try. It will be an improvement over the old 2002 Duramax for running errands and probably on-par with it towing the current 8k-lbs trailer.
If we get into 15k+ horse trailers in the future, well then the wife gets a 1-ton diesel dually and I get a Wrangler Rubicon or Bronco as my off-road and hunting rig.
Cost
Fuel Mileage
Everyday Use Case
and Penis Size
I have to show this to my coworkers with the 6.2L :ROFLMAO: .
That’s the way to do it.
As current, if I have to tow anything of value over ~10K# I just pay a local hauler with a Ram dually. Pay a small premium on fuel cost to save myself a bunch of time and headaches.
The Tremor is just too squirrelly to risk pulling things that cost more or I value more than it if I don’t have to. Nice that it can in a pinch. But only thing I tow heavy as a routine is dirt.
Cost
Fuel Mileage
Everyday Use Case
and Penis Size
That's why I went with the 7.3 - less torque needed...
Cost
Fuel Mileage
Everyday Use Case
and Penis Size
If you do in fact live in Montana as stated in your bio then the diesel fuel is pre-treated at the pump with anti gel as it is in pretty much any state that sees temps that could lead to gelling. Its pretty hard to get non-winter diesel at a pump in any sort of state with a "winter"
i wasn't sure, friends older diesel gelled up. i still see people add it to theirs all the time so I did it with the first one i had but got lazy on the last two, and apparently it didn't matter anyway
People put a lot of stuff in their tanks, not just anti gel. Could have been a cetane booster or lubricity adder
I love the numbskull that said "people only choose the diesel because they're peasants". Tell that to my $82k MSRP.
I arrived at the 7.3l for many of the same reasons as those in the thread:
Usually I'm towing my boat, which is around 4k pounds, but I do tow heavy on occasion: a broken down car or a a dump trailer full of landscaping rock or dirt.
For me, the additional maintenance and EPA-mandated emissions controls of the diesel kill it for me. Having to buy DEF, dealing with regen cycles, you really should be adding injector lubricant with today's low-sulfur diesel, fuel filter changes, etc. etc.
People talk about the hassle of filling up more with the 7.3, I think the bigger hassle is finding stations with DEF, people filling their cars at the diesel island, etc. No interest, I can't be bothered with any of it.
The 7.3 makes more power than most 7.3 powerstrokes ever did, and guys still pay $20k+ for those 20 years later. It's a dead simple pushrod V8, and should last forever.
But some people think the 6.7 makes their dingaling bigger - power to them.
I'm actually moving from a Power Wagon BECAUSE I wanted a diesel again. That said, the last item on your list is the most important part. If you need a diesel for anything in the future, you should get a diesel because you will need to buy a new truck otherwise.
