Wise IMOI couldn’t be happier with my 6.7 choice. Also bought the Ford ESP bumper to bumper 7yr/150k given the cost of repair on both engine and technology platforms. Rarely do I purchase extended warranties on anything, but decided to on this one.
My referenceIncorrect.
My reference was using 3.55 gear in both examples without realizing the 7.3 uses a 4.30. SorryIncorrect.
The TREMOR Towing Table
This table simplifies and clarifies the Ford Towing Guide strictly for Tremor variants: FOOTNOTES: These numbers currently reflect 2021-2022 models. Derate options (like the 11400# package) are not shown here and will reduce these numbers proportional to the GVWR in this table versus your...www.fordtremor.com
Towing guide aside, the capability of the motors are not the limiting factor of the 250/350 platforms. As evident by the 7.3 being used all the way up to the F550.
The 1900# delta at the top end of the gooseneck towing chart is Ford marketing playing games, no doubt. And sounds to be irrelevant to the OP as it is to all but a few members on this forum who are pulling anywhere near that weight.
I’m my opinion, 7.3 is the more practical choice, it too can handle shorter trips with a 15k trailer.I placed an order for our Tremor Lariat 7.3L back in June, no VIN yet so I can still change my mind and switch to the PowerStroke...
From reading the forums here, I can see the engine debate has been beaten to death but I figured I'd take a look from my specific use cases and ask if I missed anything obvious.
Ranking the use cases in order of 'how often'
Use Case "Better" engine choice Short in-town trips to store and barn with hay and horse feed (Partial Daily Driver for Wife) 7.3L Gas Towing an 8k bumper-pull 2 horse trailer Either one works, Advantage 6.7 Diesel Being flat-towed behind a diesel pusher RV occasionally 7.3L Gas (lighter by maybe 800lbs) Hunting trips, off-road use 7.3L Gas Future possibility... 15k goose neck horse trailer 6.7 Diesel
Appreciate any input or opinions.
I think a test drive would probably solve this one for me but no dealers around me seem to have any 7.3L in stock. Neighbor has a 6.7 so I get that experience.
If anybody in the Seattle area with a 7.3L Tremor and wants to trade a ride / drive I can offer up a BMW M2 6-sp manual experience
and yes, I can see that what I really need is both![]()
Does the esp cover all the emissions and fuel pumps? What does a 7/150 run roughly?I couldn’t be happier with my 6.7 choice. Also bought the Ford ESP bumper to bumper 7yr/150k given the cost of repair on both engine and technology platforms. Rarely do I purchase extended warranties on anything, but decided to on this one.
Believe we have some actual Ford folks on this forum that may can answer better than I, but as I understand it, it does cover most of the emissions component. The one thing I’ve read that may not be is the particulate filter (DPF). Considered a maintenance item and if you don’t allow consistent regeneration cycles, it may fail / clog prematurely. Yes on the fuel system and pump.Does the esp cover all the emissions and fuel pumps? What does a 7/150 run roughly?
You can add a DPF screen to monitor that and when I go into regen, I take it for about a 30 minute drive to complete the cycle. Don't have to do it every time, but probably once a month I run it get it to 0 % full. I think that will help the longevity of the filter.Believe we have some actual Ford folks on this forum that may can answer better than I, but as I understand it, it does cover most of the emissions component. The one thing I’ve read that may not be is the particulate filter (DPF). Considered a maintenance item and if you don’t allow consistent regeneration cycles, it may fail / clog prematurely. Yes on the fuel system and pump.
How many horses will you be towing? You’ll technically be adding horsepower!!!Ok, well I think that about convinces me. E-mailed the dealer to change it over to a 6.7
I can totally see myself having regrets towing the horses over the cascade mountain passes with the 7.3 and no engine brake.
Probably don't see myself regretting the 6.7 unless I have major engine issues. I have a major lead-foot and figure I'll go drive it like I stole it every once in a while to make up for the wife's in-town driving.
Really appreciate the input. This is a great community of knowledge and experience.
I have the 7.3 in my Tremor, use it as my DD and to tow our 7.2k'ish TT all over eastern Washington and trips over to the coast. No problems going over the pass and have run the coast with it from the Florence Oregon area up to Ocean Shores. I do wish I had better range at times, but have to stop stretch my legs or pee every few hours anyways.I placed an order for our Tremor Lariat 7.3L back in June, no VIN yet so I can still change my mind and switch to the PowerStroke...
Then don’t pull my trailer in my area because that’s what your 6.7L will getI’m no environmentalist, but there’s no way I would ever consider a pickup that gets 12 mpg, even if it worked out to be less expensive In the long run. I would kick my own ass every time I filled it up.
I in no way needed the 6.7, or a Tremor for that matter, but I couldn’t be happier with it.
I'd like to say we'll keep it for 10+ years but so far I've only been successful doing that with my old Duramax truck. All other vehicles seem to get traded in after 4-6 years.Then don’t pull my trailer in my area because that’s what your 6.7L will get.
For the OP not sure you listed how long you will keep your truck or predicted mileage put on per year. Which can help tip the scales one way or another.
