The lithiums have the advantage of twice to usable amp hours in the same size battery.. For instance a 100 AH AGM only has 50 AH of available power before the battery will get damaged by repeatedly running it down below 50% charge. The lithium can be drawn sown to 5%. without damage, thousands of times. So it has 95AH available in t e100 AH size. However, they cannot be charged below 35 degrees F internal temp, or discharged below about 15 degrees F.. So they should be mounted inside the trailer in cold weather. They do not outgas, they have consistent voltage throughout the discharge cycle, they are about 50% lighter and should last much longer than an AGM. But they do have a slightly different voltage and charging program than AGM, so it is best to charge them with a dedicated dc-dcd charger in your trailer. Solar charging also works well, with the proper controller. My last trailer had 660 watts of solar nd 480 AH of lithium and I rarely ever plugged in. Mostly an off grid trailer. My new trailer, a Roamer 1, has 1,240 watts of solar and 1,080 AH of lithium. It has induction cooking, 12 volt air conditioning, full time Starlink, A 2,000 watt inverter, etc, all from solar and the batteries. I will never go back to lead acid batteries. But charging lead acid bats is simple from the truck, especially with an Anderson plug. If you are considering switching to lithium, you can look up Battle Born Batteries, in Reno Nevada. They have been very helpful in the past and they have lithium bats that are designed to be direct replacements for lad acid bats. A flood lead acid battery and an AGM battery use the same chemistry, it's just that the AGM has little or no liquid inside. The plates are called Absorbed Glass Mat, or AGM, but they are the same thing. There are Gell, AGM, and flooded. Same chemistry and same characteristics. The lithiums are a huge leap into the modern world and much more powerful, while being lighter and longer lasting.
