Since this really became a thread for the upgrades I made to our travel trailer's electrical system, I figured I'd edit the first post.
Our system includes:
Original Post:
RAPSCALLION Upfitter Trailer Power Harness
I'm exploring using this as something of a switched DC-DC charger for our travel trailer. If I'm understanding things correctly, this should send 25 or 40 amps to the charge wire in the 7 pin depending on which upfitter I wire it to.
From what I can tell of my trailer wiring diagram, power goes from the 7 pin, to a junction box, to a disconnect switch, to the battery. If I were to wire this to an upfitter, what shuts it off once the batteries are fully charged?
I don't rely on my truck to charge the batteries all that often, and would prefer the simplicity and cost of this over a DC-DC charger.
Does this seem workable, or should I just go with a DC-DC charger?
- 1200W rooftop solar
- 200W deployable ground panels
- 400Ah Battle Born lithium batteries
- 3000VA Victron Multiplus-II inverter
- Victron 250|100 SCC
- Victron 100|35 SCC
- Victron Cerbo GX
- Victron GX Touch 70
- Victron Digital Multi Control
- Victron Lynx distributor
- Blue Sea fuses, breakers, bus bars, etc.
- Windy Nation welding cable and terminals
- 12V fans controlled by the Cerbo to ventilate the compartment
- 12V security camera system
- 12V hotspot
- Mopeka LPG sensors integrated with Cerbo
- 2x Victron Orion XS DC-DC chargers
- Additional 200W ground panels
- 12V conversion for weBoost
- 12V conversion for Starlink (I'm also considering just installing a dedicated 250VA Victron inverter for this)
- Mopeka sensors for fresh water and holding tanks integrated with Cerbo
Original Post:
