Featured
- OP 🔹
- #381
Can you measure from the frame rail down to the bottom of the tank in this spot? It’s about 6.5” on the TF tank
Looks right at 5.5" not counting the little ridge on the skid plate.Can you measure from the frame rail down to the bottom of the tank in this spot? It’s about 6.5” on the TF tank
So the TF tank (or the hanger rather) is 1" lower there, and the front hanger is about 1/2" closer to the ground than the rear hanger on my truck. Not a huge difference over stock., and it is above the diff as advertised.
Yea I'm real happy with all of that, it's definitely not an issue. Plus the TF tank is thicker than the OEM tank and the skid plate.So the TF tank (or the hanger rather) is 1" lower there, and the front hanger is about 1/2" closer to the ground than the rear hanger on my truck. Not a huge difference over stock., and it is above the diff as advertised.
Yeah I would have lost that bet to be honest with you. It seemed a lot lower, I’m glad to see it’s not. Nice work Transfer Flow!Not going to lie, I hoped your back and forth was going to reveal the new tank was dramatically lower than the OEM tank so I could eliminate it from my wish list...
Thank you both for doing that work, though!
We’ve been waiting forever for these details. You are the people’s champ!Yeah I would have lost that bet to be honest with you. It seemed a lot lower, I’m glad to see it’s not. Nice work Transfer Flow!
Well guys I got my tank installed yesterday. They used my truck to film the install and will be releasing a promotional video in the next couple weeks. I will try and film a quick video tomorrow and post it soon. Tank looks great. It does hang down much further than the stock tank did. The install took a lot longer because they were filming, but should take around 4ish hours in the future. I was given a tour of the factory and it was very impressive. Unfortunately they wouldn't let me watch the install at all because they felt it would expose themselves to liability. Another Tremor Forum member got his tank done yesterday as well. Nice to meet you Chris!
Haha like your color choice as well. I really like your build in general. They should have taken some photos or video of your truck for their promo material, that thing is bad ass! Enjoy the new tank.Pleasure to meet you as well Paul. You've got a sharp looking truck and the color ain't half bad either.![]()
Appreciate the compliment, but you got the ball rolling on this; it's only fitting it's your rig. Plus mine is too niche, your rig's appearance wouldn't be as off-putting to the broader market as mine would.Haha like your color choice as well. I really like your build in general. They should have taken some photos or video of your truck for their promo material, that thing is bad ass! Enjoy the new tank.
Interestingly, I just started looking at the Forscan parameter to change the fuel tank capacity. It's in the IPC module (730-03-01). There is not a setting for 58 gallons. You can only set it either at 55 or 60. I'll opt for 55 and know I'll always have more at empty.It's a Forscan thing.
You can set it to 58 in the plain English side. Alternatively, in IPC you would need to conver 58 gal to L, then round it to four numbers, which would be 219.6L. Then take 2196 and convert it to hex, which would be 896. Take that and plug it into the appropriate spots as specified in the spreadsheet from zoodad on ford-trucks.com.Interestingly, I just started looking at the Forscan parameter to change the fuel tank capacity. It's in the IPC module (730-03-01). There is not a setting for 58 gallons. You can only set it either at 55 or 60. I'll opt for 55 and know I'll always have more at empty.
I haven't used the English side. I have the spreadsheet. Thanks.You can set it to 58 in the plain English side. Alternatively, in IPC you would need to conver 58 gal to L, then round it to four numbers, which would be 219.6L. Then take 2196 and convert it to hex, which would be 896. Take that and plug it into the appropriate spots as specified in the spreadsheet from zoodad on ford-trucks.com.
Side note: I average around 12.5 mpg with 4.30 gears mostly around town driving. I topped of the tank and new MTE was 565. I'll take that.I had the new TF tank installed yesterday at a local certified TF installer here in Las Vegas and so far so good. My trunk is stock except for some airbags. I measured the stock tank ground clearance at 15 inches. The new tank measures from 13 1/4 from the lowest hanging bracket to 14 inches because the tank is built is a slight V angle from the middle out. The edges have a little more clearance. For the install, i also gave them 15 gallons of gas to use. I then filled it with an additional 35 gallons only because my grocery points only allow up to 35 gallons for $1 off. Once filled with approximately 49-50 gallons, the DTE read 335 miles. Once I went into Forscan and changed the tank size from 34 to 58 and the tank level to IPC the new DTE read 480 miles and that's with 8-10 gallons left to fill in the tank. So i suspect once filled approximate DTE will be close to 550 with my trunk. This will vary with different averages.
With 58 gallons and 12.5 mpg it should be reading 725! But could not agree more - the added range makes this a great mod! On my 6.7 mine is reading in the 900's when I fill up - with 986 being the highest so far (60 gallon S&B).Side note: I average around 12.5 mpg with 4.30 gears mostly around town driving. I topped of the tank and new MTE was 565. I'll take that.
Who in Vegas did the install?I had the new TF tank installed yesterday at a local certified TF installer here in Las Vegas and so far so good. My trunk is stock except for some airbags. I measured the stock tank ground clearance at 15 inches. The new tank measures from 13 1/4 from the lowest hanging bracket to 14 inches because the tank is built is a slight V angle from the middle out. The edges have a little more clearance. For the install, i also gave them 15 gallons of gas to use. I then filled it with an additional 35 gallons only because my grocery points only allow up to 35 gallons for $1 off. Once filled with approximately 49-50 gallons, the DTE read 335 miles. Once I went into Forscan and changed the tank size from 34 to 58 and the tank level to IPC the new DTE read 480 miles and that's with 8-10 gallons left to fill in the tank. So i suspect once filled approximate DTE will be close to 550 with my trunk. This will vary with different averages.
