For those who don't know, last year I created a survey to show transfer flow that there is a market for a replacement extended fuel tank in the gas super duty lineup. Currently you can only get a transfer tank in the bed of the truck, not a tank that will replace the OEM gas tank. Transfer flow was impressed by the overwhelming positive response and started designing a tank. I just received an email from my contact at transfer flow this morning, and the tank is finished! They have a date with the CARB, which have to approve the tank for use in California, where Transfer Flow is headquartered, before production can begin.
The tank is 58 gallons and fits crew cab short bed trucks. They said a different tank would have to be designed for crew cab long beds and other configurations. They do plan a crew cab long bed tank, it is unclear if that would be larger than 58 gallons. The tank should be about $2,000, but the final price is not set yet.
Edit: forgot to put that they are hoping to release by April.
Thank you to everyone who responded to the initial survey, it worked!
how do you get the gage recal for the bigger tank
Forscan… possibly a ford dealer might be willing to, but it’d probably cost a lot more.
Silly question, but what happens to the old tank. Could one in theory swap out their fuel tank on a toy hauler or add to it for more capacity? Or would that be a big no-no?
What is the difference between PCM and ICP as you also have to change this settings along with the number of gallons
Those are different modules where certain parameters are stored.
How much lower than stock is this tank?
In the specs they sent when I placed my order one of the lines says the tank sits above the differential. I don't think that means it rides over top of the diff, but rather the bottom of the tank is above the height of the differential. That's still a little vague but I think they tried to maintain ground clearance. Hopefully as soon as someone gets one installed they will share some pics.
I asked Teri about this, and she said that it sits about the same level as the stock tank, though because of the straps the tank technically sits close to 1" lower than stock. IMO that's hardly anything all things considered.
First person who got their 58 gallon TF tank installed posted a couple photos and a writeup:
Well guys I got my tank installed yesterday. They used my truck to film the install and will be releasing a promotional video in the next couple weeks. I will try and film a quick video tomorrow and post it soon. Tank looks great. It does hang down much further than the stock tank did. The install took a lot longer because they were filming, but should take around 4ish hours in the future. I was given a tour of the factory and it was very impressive. Unfortunately they wouldn't let me watch the install at all because they felt it would expose themselves to liability. Another Tremor Forum member got his tank done yesterday as well. Nice to meet you Chris!
When I called after getting the email I asked about this and was told by TF that it only comes down 3/4" lower than stock.
Can you measure from the ground to the lowest point in the front of tank and from the ground to the lowest point in the back of the tank?!? Whenever you get the chance.
I'm a little worried about what "much further" means cause that sounds a lot more than 3/4".
I guess it's subjective, but it looks like it hangs down further, maybe it's because the tank is so much bigger. I wish I would have measured the OEM tank before the install.
The lowest point is definitely the front strap. They used channel instead of flat bar for the straps, and the flanges hang about an inch lower than the actual tank. I'm guessing that the channel is much stronger than flat bar?
I measured down from the frame rail on the drivers side to the bottom of the tank and got:
Front of tank: 2 3/4"
Front Strap: 5 1/2"
Back Strap: 6 5/8"
On the passenger side from the crossmember down 14 3/8"
Measuring from the ground up to the bottom:
Front of tank: 14 inches (Driver) and 14.5 inches (Passenger)
Front strap: 11 7/8" (D) and 12" (P)
Back strap: 12 1/2" (D) and 12 7/8" (P)
Back of tank: 13 7/8 (D and P)
These measurements won't mean much for comparison purposes unless someone has the same tire and suspension as my truck (F250, 6.2, non-tremor, camper package, 35x12.5 Toyo MTs).
Amazing photos thank you very much that's going to help out a ton of people. Thanks for taking the time.
I just measured stock tank/skid plate from the front drivers side strap and to the tank it looks like it's only ~1" lower (3 1/2" right at the strap).
The channel flange drops down lower like you say, I'm sure for strength and probably takes some abuse before the tank gets hit if you were going over a rock or something.
Can you find the lowest point of the OEM tank from the frame rail? Does it hang lower in any place than the 6 1/2 inches of the TF tank?
This is from the driver side rear strap going all the way up (the back strap is a lot longer than the front).
Another point:
Is it me or does it look like the TF tank isn't nearly as long in the back as the stock tank? The OEM goes way past the bend to the upper frame.
