First off do you have the rest of the trailer tpms system that Ford sells with the truck? I ask this because the sensors come with the system. The sensors alone will not connect to the truck without rest of the system.If you order the sensors, are they screw on valve stem types or do they need the trailer tires dismounted?
Yes you have to buy the base harness kit with cable and plug for the truck. Plus the TPMS kit. The extra plug takes two seconds to plug in at every hook and unhook. No big deal. Install for just the TPMS is all zip ties and cable management. More work if you add the camera and need to run it through the walls of the trailer. I have seen reviews it is way more reliable than the truck mounted receiver on long trailers. The receiver is mounted close to the wheels and has a good signal.I think I have asked this before, but can't recall:
For just TPMS, is the 2nd cable required to connect to the trailer? Or is the receiver mounted on the truck?
I probably wouldn't bother if there is an additional cable and hardware to install on the trailers.
The truck was set up from the factory. It's having to buy 4 trailer side kits that would be the show stopper. Too much money.Yes you have to buy the base harness kit with cable and plug for the truck. Plus the TPMS kit. The extra plug takes two seconds to plug in at every hook and unhook. No big deal. Install for just the TPMS is all zip ties and cable management. More work if you add the camera and need to run it through the walls of the trailer. I have seen reviews it is way more reliable than the truck mounted receiver on long trailers. The receiver is mounted close to the wheels and has a good signal.
