Trail ready and buck stop front bumpers
That antitheft feature is pretty slick ^^^.
If you are okay with storing in the truck, its hard to beat the reliability of a Crosby shackle. Not to say anything ill of what @HvacSciGuy shared because I dont know anything about the brand above, but be weary of nearly all shackles. So much untested Chinesium out there. I hear horror stories OFTEN. These trucks are so heavy too... If people are snapping crap with a Jeep or 4runner that weighs have as much as these trucks... a HD will snap an untested metal like a tooth pick.
Where these are manufactured and how they are tested in order to come up with the alleged 80,000lb strength IDK. But if they're even half that strong then I'm plenty happy with trusting these over the ones they sell at harbor cheap/tractor supply.
Mostly likely a horizontal tensile test bed...biggest I have seen went to 250t...
I miss the testing days...load testing custom built crane spreader beams with water bags was my favorite some kind of shenanigans would always ensue.
Thanks @HvacSciGuy, my TrailReady brother! We work hand & hand with Buckstop to get the exact configuration you are looking for.
You can check out many of their offerings directly on our site here.
Main differences
  • TrailReady is only available in 100% steel configuration
  • TrailReady bumper "wings" on either side are three piece vs Buckstop is a two piece, which essentially means its a large flat surface and doesn't have the chamfered corners
  • TrailReady comes standard with welded recovery points
  • TrailReady in certain configurations is a little thicker
  • TrailReady grill guard is welded on.
  • Buckstop is available in all steel or a hybrid, which is an aluminum lower section and steel upper hoops/bar work. The hybrid saves 90lbs.
  • Buckstop as standard uses the factory recovery points with the option to upgrade to weld on recovery points
  • Buckstop has more three hoop configurations than TrailReady, all of which are bolt on.
We have the option for custom light configurations, receiver hitches, additional protection across the headlights (see my truck below), and some other tricks some might not know about.
/View attachment 184589
Are those trail ready smooth lips?
I have a Buckstop bumper and Warn M 15000 winch on my ’02 F-350.
The bumper is very strong, and it was very expensive. However, I have a gripe about its construction, and considering the cost of the bumper - I think it’s a legitimate beef. It has a front 2” receiver for a trailer ball mount, and the new bumpers apparently do as well.
But the so-called "2” trailer receiver" is not a proper receiver hitch tube but rather ERW square steel tubing (Electronic Resistance Welded) with a hole for the hitch pin. What’s the difference? A no-kidding receiver tube is smooth on the inside whereas ERW square tubing has that weld sticking up on one side internally. A standard 2” ball mount fits loosely in Buckstop’s version of a 2” trailer receiver.
For a company that brags about its quality, they shouldn’t cheap-out on this feature.
must be the same people that made my factory receiver. Its crazy how sloppy my B&H hitch fits in it. My previous truck (Chevy) was nowhere near this.
You got a good eye! I had seen them do it on some jeeps a few years ago and had them custom made without the beadlock ring.
If you interested Id be happy to get you a quote. When Dan @ Carli Suspension saw them he about fell off his chair
G
G
Don’t mean to hijack here, but I’ve been drooling over those smooth lip Trail Ready’s since you posted them on Instagram a few months ago, what backspace are you running? Their design is so iconic I just can’t make up my mind between the 17‘s and the 20’s
Im biased but I think its the best looking wheel for these. 5" backspace.
Reach out! I can get you a quote.
@reijos when you get a chance show these fine folks what you TWO goodies you ended up with last month! 😜
Got the front and rear from Buckstop along with a winch installed a couple weeks ago. Love them so far.
As an unrelated side note, after this weekend I am able to confirm that 8X 8&under hockey players fit in the bed while 5 adults eat lunch on top of the tonneau cover
Main differences
I’d love to replicate this setup on my 22 F250 Tremor, and add the TR rear bumper. You mentioned you sell these?
