TPMS Fault
These people are a joke
I don't want to be fanning the flames here, I hope more to give you info to "help" them along. Still hope you some good luck maybe a tech will hit the right key on the computer.
Have any of you had sensors that failed? My truck has literally been at ford for a week due to this! They have replaced sensors 3 times and still after driving 20 minutes it fails. Are they being lazy and not digging deeper? Keep saying they must be faulty sensors from factory
Driver rear is culprit
I have the same Problem on my 2022 f-250 Lariat Tremor. I continually get TPMS errors on the rear passenger tire.
weird question, do you have a TPMS in the spare that may be sending a conflicting signal and say the stem is closest to the passenger rear wheel? Normally the stock spare does not but just spit balling and seeing what might stick vs dealer just throwing TPMS at the same wheel over and over.
Second question, if you rotate the tires, does the issue follow?
Not sure on rotation if the problem follows wheel. Dealer still has my truck, this is getting out of control for a stupid tpms issue
Damn dude that is terrible. I would challenge the SA with that. At this point what do you have to lose since they clearly can't figure it out.
Got truck back today and light back on. They are going to call another ford dealer to look at it next as they can’t figure what is wrong. Replaced all sensors and module and still shows one tire as not responding
Sarasota Ford will be calling me Monday to schedule appointment. I gave them the run down and they were not sure what else it could be either. Will see…
If you have the means, switch the problem tire with another (maybe front). Change pressures around to see if the problem follows or if it doesn’t change on your dash. I can’t imagine there would be a ton of modules to deal with but I’m no ford tech.
This would at least give more data points to get it sorted.
I just read through this entire thread and about half way through the first page I was wondering why they wouldn’t move the “problem wheel” around to first determine if it’s the sensor or the module?!
I went through a troubleshooting course years ago and the instructor hammered into us daily, “don’t be a part changer! Identify the problem” he’d say.
The flat rate pay system is what drives this problem at dealerships. They don’t get paid for troubleshooting.
I don’t think most techs have the ability to troubleshoot, because they’re not really mechanics anymore. Their lives are driven through the OBD port: the computer diagnoses the problem, and the techs replace the indicated module/part.
We had a family vacation ruined years ago because the Ford 450 that carried our Class-C kept getting stuck in park. I stopped for fuel and then the truck wouldn’t go into drive. We got towed to the dealership where we spent most of the next couple weeks as the techs intermittently replaced components. They simply followed a flow chart, serially replacing components, most of which required two or three days shipping. They were nice people doing their best, and they were on the phone a lot with Ford engineers, but each successive repair plan had to be authorized by the guys they were talking to in Michigan. Finally, on day 14 or 15, an old mechanic found a wire that was intermittently shorting on the RV frame. They wrapped the wire and the RV ran like a watch from that moment forward.
I miss having old style mechanics at the Ford dealer — the crusty old guys who could build a motor and transmission from scratch and diagnose lots of problems just by listening to the vehicle and driving it. I don’t think they train guys like that anymore.
The other interesting part is the light isn’t on all the time you have to drive it awhile for it to come on. While you are waiting for light all 4 sensors are reporting psi
Wait, random thought, do you have the trailer tpms (that you can elect to purchase but not installed) anywhere in the truck? Say stored in one of those bed fender area boxes? I wonder if it's those.
Not 100% but my 2015 had an on again/off again TPMS issue as you describe. Until I did some ForScan changes did I see a DTC in the menus....TPMS module. I didn't care about it so I turned off the TPMS, no more issue. 😜 😜
I hate the ever-increasing, gubmint-mandated, lawyer-proofing, nanny features. The new “spill proof” gas cans have multiplied my spill rate from near zero to nearly always… My 2019 Jeep Wrangler automatically shifts to park if a door is ajar. Damn irritating. Pretty soon I’ll expect the vehicles to be disabled until the driver is wearing a helmet and a nomex suit. Having said that, TPMS has saved my ass several times, including once on my motorcycle, so I appreciate having it when it’s functioning properly.
43k+ miles on my 22. On a 3 hour drive pulling the TT I got the passenger rear TPMS fault. I pulled over, checked my actual pressure, and kept going. Over the hours it fixed itself and broke again 3 times.
I have the Ford trailer TPMS. It was active on this trailer. When I lose my rear passenger tire the four trailer tires remained with what looked like valid pressures/temps.
I had just aired up for the tow. Otherwise nothing of note happened.
My truck and this trailer combo (with TPMS) is just shy of two years. My TPMS were moved to new wheels/tires.
Same issue with my 2022 - OEM 20" Lariat Sport wheels on 37's.
TPMS fault error in one wheel only, usually triggers after 15-20 min at highway speeds. Sometimes it'll correct itself quickly, other times it'll stay on for 30+ min of driving then correct. It started as driver rear sensor and followed the wheel after a rotation.
Weird how it only triggers while driving at highway speeds.
Or hit the tech with his computer.
Did they say if there is a code that is being stored? If so, what code? (this would be stored in the BCM).
There are 4 "modules" involved in the TPMS system on the 2022 for the truck itself, and a 5th if you have the trailer TPMS...
RTM - Radio Transceiver Module
GWM - Gateway Module A
BCM - Body Control Module
IPC - Instrument Panel Cluster
PCM - Powertrain Control Module (if equipped with Trailer TPMS)
First thing they should do is induce the problem, then rotate the suspect wheel to see if the issue follows the wheel, and then rotate yet again to confirm the issue following the wheel or not.
1 - Ask them if they have confirmed that the BCM is receiving TPMS info/correct info, from the RTM (they can compare the pressure reading at the tires and on the diag screen. If these do not correspond correctly, then they have isolated the issue to being the RTM or BCM. IF the actual tire pressure is in agreement with the RTM and BCM, then they need to look at the IPC.
2 - Ask them to identify the faulty TPMS sensor via the BCM before replacing it, and to confirm the new TPMS is identified in the BCM.
All of these modules communicate on CAN systems. I would not think it is a CAN system issue, or you would be seeing other faults as well, not related to the TPMS system
IMO, the BCM is the most likely culprit as being faulty and causing the issue because there is a software coding problem. (because your not the only person to have this complaint).
That's about the only info I can give ya without actually having the vehicle in front of me for diag
