44’ with a 7.3 350. 13,800 empty weight with just over 2500 pound pin weight on paper, so very similar to yours. Payload of 4404 pounds on the pickup. This was pulling it home when it was new. Pulled it across a Cat scale here. Pin weight was right where it said it was and I had quite a bit of stuff in the front storage as well. IMO, I’d say the 2500 pin weight on the specs is correct. Definitely not 3k. Are you going to be overloaded on your rear axle and payload? Very likely. The vast majority of 3/4 ton trucks pulling a 40+’ fifth wheel are.
