Towing a fifth wheel travel trailer
Roadtripper
Ca.
2022 Ford F250 6.7L Diesel Tremor
Does anyone use the Ford towing calculator? I have a 2022 F250 6.7L Deisel Tremor ( 2909lbs) payload max. Purchased a 2026 - 43' Campsite Elite 36AK fifth wheel travel trailer (13,383 dry /16,200 GVWR) 2540 hitch weight with 2817 payload max capacity. I have ran the numbers over and over with the my truck and trailer. Seems like I'm right at the maximum payload maybe even slightly over with me and my wife and B&W Patriot slider hitch. I don't fill fresh water for travel and only basics are loaded in the trailer. I also installed RideRite Firestone airbags for stability. We went on a short 140 mile trip just for a test run. Couple steep inclines and some curvy roads. But mostly freeway driving. Felt good and even reduced the trailer braking gains to 5.5 from 6. I wanted to test for sway or vehicle push or pulling. My truck very much felt like the boss. I realize that I would be much better off with a dually with a higher payload capacity. But I would like to hear from anyone who has the similar set up and their experiences.
Plenty of us on here that tow heavy. I have used the app and it works fine. The real question is your pin weight. Have you weighed your unit yourself or are you going off what the dealer/manufacturer told you when you bought it? Two VERY different numbers. For a 43’ fifth wheel 2500ish lbs seems way too light. Rule of thumb is 18-23% of GVWR for you ACTUAL pin weight and even at 20% you’ve busted your max payload without even adding passengers/cargo in the truck. Also have to take into consideration axle weights. I know numbers can vary with payload.
I’m very vocal against knowingly towing over max payload, and for good reason. We spent over a year finding the right 5er for our family of 6 and finally bought earlier this year. I ran the numbers over and over to make sure I would be legal AND safe. We all know these trucks will tow most anything you can hitch up behind them. I don’t want to be towing next to the guy who couldn’t care less and puts my family’s safety at risk on the road. Don’t be that guy (I know we have some of them on here).
Any questions feel free to reach out.
Good luck 👍🏼
Hitch weight sounds a little low for a 43' trailer, when not sure you can hit a Cat scale or DOT scale for true weight. I tow a 35' grand design 5th wheel using just a set of Timbrens no air bags hitch weight is just under 3,000lbs tows great. get around 8-10mpg. I agree with @gmbpilot757 and like to stay under GVWR have heard of folks having issues with insurance if there ever an incident.
If the fresh water tank is behind the axles you can fill it to take some weight off the pin. I bet that beast carries some serious tankage.
Good luck 👍🏼
Good luck 👍🏼
Good luck 👍🏼
Yes 2540 lbs pin weight does sound a little lighter for this trailer. I got this off the trailer spec sheets. I do plan to drive over to a cat scale to get real numbers.
That on weight should be in the 3k range. I know I sound like a weight cop, but too often I hear people say “we travel light”. You old be surprised at how much the basic stuff adds up to. The paper specs also don’t account for propane that is often carried in front of the axles.
I’m sure you know, but no amount of accessories will help the axle rating of your truck. They actually hurt by adding weight.
I see you’ll be getting a legit weigh in, which is a good thing!
I would bet the you will be over 3,000 or more for actual pin weight not sure why manufacturers understate pin weight. And that’s before you put anything in the basement (front compartment) or the passenger thru storage area and it adds to the pin weight fast.
What are you pulling it with? I thought of going with Timbrens and just decided on airbags. The roads weren't the best but the ride felt smooth.
Stock 24 F350 Tremor with Timbrens is all no sway bar ( had one didn’t notice any difference so removed it) am getting ready to do a Pathfinder level kit and keeping the rear suspension stock for now other than the pathfinder shocks. Will upgrade to the progressive leaf pack when we move to a smaller bumper pull trailer.
I’ve been looking at toyhaulers and my concern is enough tongue weight with my SxS loaded. It’s super annoying manufacturers don’t have published actual pin weights with standard and popularly equipped units so one could calculate the pin weight. They also don’t publish CAD drawings or locations of the tanks so without bringing a tape measure and my calculator and seeing a model in person I can only guess and even then I don’t know if the published pin weight is even remotely accurate.
I am doing one with a gooseneck hitch no matter what so that will save some payload or at least make sure the weight is on the trailer pin not the truck.
Also one of the things our sales guy pointed out is they are taught to sold by the manufacturer which units for which series of pickups. We looked at a Brinkley 4000x and he was like; Brinkley claims the X series is good for 2500/250s. I said I don’t think my F-350 SRW will be enough, that’s a lot of pin weight. He was like, you’re totally right Brinkley just tells us to say that.
Invest in a scale. I did, and it’s paid for itself in time and frustration.
