Tire Pressure for Winter
Stock Tremor Duratrac’s were 3PMS and somewhere along the way in late 21 changed to non 3PMS rated tires
Mines a 22
That's certainly another key factor of temperature swings along with heat up from driving. Do you ride lower pressure for winter?
I keep the pressure the same, which usually means adding air to combat the drop in pressure from the temperature.
Here is an article you might find interesting: HOW DOES TEMPERATURE CHANGE AFFECT TIRE AIR PRESSURE?
From another forum, "Lower tire pressure will not give better traction in the snow and ice. Higher pressure reduces the tire's footprint and increases the "normal" or force per square inch. Smaller footprint with the same weight means more normal force for friction or traction thus more Bite! Lower pressures cause the tires to float over snow with less bite. That is why you would want a narrower snow tire in the winter. In the mud it is the opposite. You try and float over the mud thus lower press. at wider tires."
Of course this doesn't apply when offroading where lower pressures may improve performance.
I figured the skinny profile of a tremor tire would create less contact thus less traction. I have yet to use my truck in snowy conditions. I will certainly use the snow/slippery road mode for sure. I never thought of weighting the bed, I figured the weight of the truck would be sufficient. Thanks
For ice pound per square inch of contact comes into play with traction but airing up and down while staying high enough for highway use will likely have a minimal effect in my experience. Best gains in traction outside of chaining up for me has been adding weight in the box, but have the older 3 peaks mountain snow ratted tires. My Grandpa had a old DRW that he would pull the outer rear wheel to give a quick cheap gain in traction in the winter. Was impressive how well that old 2wd F350 dump bed would get around with the outer dual removed.
Funny I just saw this. Yesterday I took off my Fuel beast wheels and Nitto tires. I replaced them with the Factory duracraps and stock wheels. I made a change on Forscan ( a while ago ) to set the tire pressure threshold down. I am at 51 fronts and 53 rears right now. We have about 2 inches of snow on ground and temps anywhere from 9-35 next ten days. no more snow on forecast. Lots of salt on the roads now and cars are turning "white". I figure the factory tires are narrow and better suited for snowy roads than my aftermarket wheel and tire package ( as they are much wider). I used to own a snowplowing business and we always ran "pizza cutters" on the plow trucks. They are narrow wheels and tires with big lugs so there is lots of pressure points on the road and wide enough gaps to self clean if you get into heavy stuff. Driving on the snowy roads you do not want to " float" on top you want to push down onto the asphalt. So the idea is to have a tall narrow tire. The factory tires are perfect for snow covered roads.
IMO your tire pressures shouldn't change based on the season, but based on the weight your tires are carrying. Under-inflating for the load while going highway speeds, regardless of season, is how you get tire blow-outs. It's also how you induce handling problems, particularly during emergency maneuvers, as the tires squirm and fold over due to the lack of pressure.
That right there is the answer.
That's a logical explanation, makes sense when explaining it that way. Looks like I'll be adding air!
