Tire Low Pressure Light
JJTremor
Tremor Fanatic
Illinois
I've suffered with this warning message for the last month straight and it started the day after I picked the truck up when new. Initially tire pressure was LF 55 psi RF 53 psi LR 56 psi RR 59 psi. The stock door sticker says Front 60 psi and Rear 75 psi. I decided to fill front and rear tires to 60 psi all around and I've been driving the truck and the light still hasn't turned off this entire past week. Do the tires have to match the door sticker to turn the light off? I know my other vehicles I've owned in the past were more based on a pressure imbalance between all the wheels.
What tire pressure are you guys running in your stock tremor tires?
Yes I believe this is correct. Pressures need to meet the factory specs or else you get the warning. These limits can all be changed in forscan to avoid tpms warnings.. I have messed with tire pressures a good bit over the past 6 months. I found that unloaded my sweet spot with factory tires is 60 front, 55 rear. When towing our 5k trailer, I run 60 in the rear.
Edit: adjusted specs
I have my tpms warnings set at 55 front 50 rear
Yes I believe this is correct. Pressures need to meet the factory specs or else you get the warning. These limits can all be changed in forscan to avoid tpms warnings.. I have messed with tire pressures a good bit over the past 6 months. I found that unloaded my sweet spot with factory tires is 55 front, 50 rear. When towing our 5k trailer, I run 60 in the rear.
Thanks for the heads up. I've used Forescan with OBDLink MX on another ford so I'll need to look into this.
Still looking to hear from others what they like to run a stock Tremor on as a Daily Driver and not towing.
Tucson Tremor is correct. There is some initial wiggle room, where if you go below the set pressure it won't immediately light up (need to go maybe 3-5 psi below for it to light up), but once it does you need to get back to the set pressure for a bit of driving time before it will go out again.
As you seem to know already, the way to change the threshold is with ForScan. It can be done in Plain English and is super easy if you have the adapter already.
I run 60 psi all around and am happy with it. Truck would likely ride better at lower pressures, but 60 psi guarantees I can run fully loaded without having to think about my pressures and since I'm happy with it I'm not going to bother going lower other than lowering pressures for extended off-pavement driving.
Check out these threads for other pressure recommendations:
I agree with this. I believe the logic will allow 20% low (I'll have to verify my own notes on this) and if you trip the alert you have to fill back up to where the placard is set.
