Remember, the tire inflation chart is exactly what it says- MAXIMUM load for a given pressure. So at 60 psi, you are maxing that tire out. IMHO that’s not ideal. You have more sidewall flex and tread ply/ carcass tension. That builds heat as @LWS witnessed. There is a rule of thumb that the ratio is 4:20. For every 20*f increase in temperature tire pressure increases by 4 psi. Hot tires (and brakes) tend to fail.
When towing heavy, I always go within 5 psi of the tire max inflation in the rear and start at door jamb listed pressure in the front. I’ll adjust front of the steering feels light or tracks weird on the highway.
