Tell me about bigger tires and all the tech issues or non issues with a platinum.
I know you can correct the speedo with forscan. Question is more do you have to?. Local shop is telling me 37s are not going to make the speed off enough that it is required to correct for auto cruise etc. ?
I have 37s on my 2023 F-350 Platinum (although as others have stated, the trim level doesn't make a difference). I do have a leveling kit, but you should be able to fit the majority of wheel / tire combo in a 37" without any issues.
The speedo is off, most noticeable at higher speeds where it can be as much as 5+ mph off when you're going 75+ mph.
There is a process to adjust the tire size in Forescan, but Ford has hard coded an upper limit to tire size. There is a thread on the procedure to get a larger than OEM tire size to work (up to the hard coded limit) which will help address the accuracy of your speedometer, but won't make it perfect. I personally haven't been able to make the somewhat complex process for getting the new tire size to work, so I just live with knowing that I'm a few mph over what it says on my dash when on the highway.
A couple of other things I noticed. If your truck has adaptive cruise with lane centering (not just lane keeping), the lane centering doesn't work as well with larger (predominately heaver) tires. I find that going around bends in the highway that I have to provide more assistance to the system then when I had the Duratracs on the truck.
If you have the auto-leveling headlights and bed scales, you'll need to address this if adding a leveling kit. Carli sells a bracket that you can use to lock your headlights in at a certain position. These do change them from auto leveling to fixed as well as negates the bed scale from measuring weight. There is a company that makes replacement billet aluminum arms for the sensors that are sized based on the lift you have that could help you keep the functionality, but I can't recall the name of the company that makes those parts.
Wicked Trucks is one of the companies that make the kits that will keep the headlights and scales fully functional. They also have options to replace a lot of the plastic that makes them up with aluminum for durability.
There’s another company that makes adjustable ones I thought - basically acts like a turnbuckle tensioner to make the arm the right length.
(This is only for once you lift or level I believe - not required if you just go to 36/38s on factory.)
My mechanical OCD is too pronounced. I can't live w a speedometer that reads either side of 1MPH to GPS.
I'm cursed.
Fixed it in my 2016 F150 when regearing for 34" Toyos, but the FORScan hexidecimal for mm tire circumference was outside the accepted FORScan input parameters... so we had to fudge the gearing hexidecimal to get FORScan to read the correct tire size. Two Canadians on the F150 forum helped me a great deal. It's perfect.
That said, I couldn't do that again without help. I don't use FORScan often enough to remember how to use it. Aaaaagh.
:ROFLMAO:
And after waffling about swapping from 35s to 37s I am certain I'll be going w/ 37s, so I'll be asking someone for help in the near future. Still have some life in my fresh 35.1" Duratracs!
Just curious. What is the benefit to going to 37's?
Appearance, another inch of ground clearance, better ride.
Downsides are in Colorado you can’t get emissions with them (or 35”s for that matter but stock 285s probably would be allowed since they don’t say “35”)
If you off-road it’s crazy how much difference a somewhat bigger tire makes in clearing obstacles and getting out of ruts or whatever.
Tit’s,Tires and Track’s, the bigger the better. Stock is lame. Don’t want to spring for 38’s-54’s. Chicks dig them. Who wants a metric size tire on their rig. Some may say the added ground clearance, approach and departure angles. But we all know, it’s because chicks dig them.
Speaking from a 24 platinum 350 with a full Pintop w HD springs on the rear, and 37's on 18x9's. Everything I've done, I'd do again exactly the way I did, with no regrets. I came out of a 2004 CTD with a KORE lift w Kings on 35's. Never had the death wobble on the dodge, nothing close to it, but it was mainly to get the progressive springs and get 35's under it, and going to 35's on a dodge was a night and day difference on smoothing out the ride, not to mention the trail benefits. On TDR for 20+ years. No offense, but it was common knowledge that a 6" w/ 37's was a prom invite to dance with the devil so far as the death wobble was concerned, soooooo.... my take on your concerns.
Headlights leveling- if after "level", you run soft progressive springs in the rear, and subsequently load the bed or the hitch, it could be an issue. I'm running HD progressives in the rear w air bags (yet to be used) and rear sag is a non-issue. Headlights are secured in the perfect spot, and I don't miss the auto leveling feature a bit. It's a nice feature I have on a Defender we drive. If the headlights turned left or right as well as up and down, that might be something you might miss. I don't dig the fog light assist with turning. Pretty cheesy and useless. Would I play with a kit to get it back after the 3" lift?.... maybe but that's pretty far down the list that it's not even on at the moment.
37's on a 9" wheel - Best bang for your buck, and it's not even close. I'd do 37's over 35's every time unless a 5th was involved, and even then I'd go with the 37's. Speedo, cruise, adaptive cruise, lane assist, and anything else you mentioned or are concerned with; a non issue. I've had zero issues and everything has been as it was. I live with a mental 3-4% correction when looking down at the speedo going down the road. Same as my old truck. A non-issue. I'd rather do that than complicate anything, but I have a forscan subscription and the setup to change it if I ever felt the need, which I haven't.
Scales in for the bed - This is just me talking, but I always thought that to be pretty gimmicky and have no concern with it. I have a pretty good idea what's in the bed when I load it, use a weigh safe in the receiver, and would probably use something similar if I pull the shell off and ran a 5th.
Do the 37's with a +12 offset and you're good. If you want the level for cosmetics, actual useful increase height, go ahead, but I'd get the best you can afford with the shock upgrade being your focus. A Carli lift/level on a Platinum is a good fit. Good ride quality cost benefits there too. Spoken from experience. I can't comment on BDS other that I passed on it. If 37's, or even 38's are what you're looking for, stick with a 2-3" leveling package. I have a hard time imagining the need for a 5-6" lift on a Platinum. I even have a hard time with the want, since I can't imagine the desire to beat up a Platty in the dirt either
Great insights thank you!!
37”s on my Ram were no issue with death wobble but I had the Thuren full suspension (only 1.5” level with rear airbags.) Honestly there’s more room for tires on the Ford.
To me the advantage to the 3.5”’(Tremor) full kit from
Carli is the additional travel but to your point if you aren’t running fast on trails it’s probably not worth the height.
I’m kind of disappointed in the scales. I’m glad it was part of the Platinum package and I didn’t add it.
Been pondering wheels for a while. I was going to just keep the oem tires but nnw have been convinced to upgrade those too. I know a 35x12.5 won't cause issues but will a 37? I have a 26 platinum so it has all the nanny stuff. I have learned to love the auto cruise on highway drives. If I step up to a 37 tire do I have to adjust with forscan or the like or will,it be OK? I have been told it's "not necessary" for just 37s. Can't wrap my head around the speedo being off and that system still working properly.
What about a small level like the BDS kit. The auto headlights and the scales in the back, does their kit for the sensor solve it all or has anyone had issues? Warnings or other adjustments needed?
This stuff is all really easy in the jeep world but our jeep has far less to deal with too. No ADAS, no moving headlights, no scales..... But man I hate warning lights and all that. I have been leary of even a level kit. I had a 2004 ram 2500, did a 6 inch lift to fit 37s and it eventually developed a death wobble that took forever to sort out all the while costing me more and more money. Just want to know what to expect up front.
My input. Larger tires are heavier, more rolling distance as well as rolling resistance, which makes final gear ratio smaller, which puts added stress on drive train. MPG goes down. I am leaning to a smaller tire when the OEMs are wore out. I live in Colorado. A little more power would be welcomed. I don't get into anything off road that small tire height would be beneficial. Just my opinion.
Pine; you're just across the road from Slaughterhouse. That's a fun, easy trail.
Lol. I live in Colorado. In the bumpy part of the map. Not the city
6.7 don't give a shit about tire size. In fact, I'm quite convinced my truck will be even quicker, and getm better cruising mileage with the 37s as opposed to the 35s.
You're considering SMALLER tires? :ROFLMAO:
The Maverick has smaller tires, and a much better power to weight ratio than the 7.3 Tremor. Maybe if you hurry you can trade your truck in for one of those Santa Cruz hybrids before Hyundai runs out of them. Maybe even a Ridgeline if you're looking for more power. :ROFLMAO:
Tee hee...
I couldn't let that go.
Good times, Great oldies!
Just fuckin with ya, @tgile7
Important detail... his profile says he has an F-150 Tremor. There is the f150tremor.com forum that we sometime get people here that might find more relevant content for their trucks there.
Can’t blame them for wanting to hang out with the cool kids, though 😜
Also, should anyone that champions smaller-than-stock tires on an off-road package truck be permanently banned?
Kidding.
Mostly.
Don't @ me...
Kidding.
Mostly.
Don't @ me...
@McE
Yes. Ban the imposter!!!! :LOL:
I had considered lowering my previous work F150s, and did put tiny tires on one of them. Because they all had ladder racks and I'm pretty fuckin' short.
Now, I just throw my big ladders on a trailer instead and am looking at wider rims and taller tires for my Tremor.
Can't wait to finish destroying these tiny little 35s. These truck should have come stock with 9" rims and 37"x12.5" tires. Or at least the 9" rims. It's bullshit that they don't.
Fight me.
  • Haha
Reactions: McE
