Suspension upgrade without a lift kit
That is what I did with them and the results were awesome.
Is there something on the market that will give the Tremor a smoother ride without going to a full Carli system? Would it be as simple as just changing to FOX or King shocks? I don't want a lift. My parking garage at work is already a super tight fit and with any lift I'd no longer fit, so that's not an option.
Coming from an 18 Raptor, I'd like something that maybe has a bit more travel, and doesn't feel the pot holes and speed bumps. Right now they kind of rattle my teeth.
Thanks
Hello driftwood here’s what I’ve done and I have to say the ride has improved quite a bit!
lowered rear with PMF 1-1/2” blocks
AirLift 5000 bags (5# air pressure with no load)
Helwig #7320 Sway Bar
Rides pretty darn smooth now and adding the sway bar got rid of the rear wheel hop when hitting bumps!
Just my 2 cents
Just my 2 cents
Also running 60# front and rear
Check out Acutune!
You’d surprised what custom valved shocks are like without relying on a full Carli suspension.
Exactly what Txfoster said. Check out Accutune! Although I am not a Tremor owner yet, waiting on my truck. I have experience with Accutune shocks on the F-250. My 2017 was a gasser, Carli would not support mixing parts with a proper gas spring at the time so I did more research. Ended up with a Ready Lift Level kit up front and a set of Fox 2.0 Reservoir Shocks from Accutune. All I can say is after all my years of playing with cars and trucks that hands down that was the most surprising ride change I have ever felt. Never have I had that kind of vehicle response from switching to Bilstein's or any normal of the shelf shocks. Yes, I have had improvements, especially after changing worn components, but healthy new shocks vs a custom replacement, never. Currently I am contemplating a full Carli Build Vs Accutune when my truck is here. Honestly, the $1250 I spent last time with Accutune is super attractive, even it is just until I save enough cash for a full Carli Build, the ride improvements are phenomenal and worth the cost and I can sell them when I am ready to upgrade.
