I wondered the same thing and did some experimenting. Although I am gonna go with a carli 3.5 kit because I do want a bit of lift( which actually only lifts the tremor 2 inches).
But my current setup rides considerably better than the way the tremor came, which is;
Carli full leafs with pmf drop shackles to get the rear back down to factory height. On the lowest setting of the shackles, the rear height is in between the f350 and f250 tremor height. For load handling I will be installing air bags with daystar cradles.
The front I installed code t coils from a 17-19 truck which are a half inch lower than the tremor coil but ride a little softer.
Using the tremor shocks. A lot happier with the ride. The front I do have a 1 inch coil spacer which puts it half inch higher than factory with the coils I have.
