waiting patiently to see if anyone is successful in bumping the factory speed limiter past 96 without an ECU tune lol.
Glad it should be fixed (keeping my fingers crossed for you that Ford’s instructions work). Stupid it took so much work on your part, though. And glad you’ve learned you have dealerships at least somewhat close to you that are willing to actually dig into problems in case something else comes up in the future.Update: Finally got a call back from selling dealer with a load of bs communicated by the manager through the relatively new rep.
- The truck is too big therefor it’s been limited on speed, sorry we can’t undo that.
- Go ahead and do it yourself it won’t void warranty.
- both fleet and service managers racked their heads together and came up with a law that due to its GVWR (11300lbs) is limited to 120km/hr (75mph) and that it’s normal.
I called a dozen dealerships in and out of province. Not one had come across this issue on any super duty. A couple of them seemed to really want to help and figure out the problem. I was ready to make a days drive to one of them. As the manager called me directly and said to bring it to him and he’d check the PCM for me.
Today I get a call from the service rep from the selling dealer in town and he said he got an email back from ford engineering with the exact instructions I gave them 3 days prior. Truck is in right now, fingers crossed.
Here is the email from Ford Engineering if anyone needs it in the future.
How did you do this in Forscan? Do tellHere I thought it was bad at 80 MPH because I leg it sometimes so easily. I just changed it with FORScan to 120 MPH and i also set police mode haven tried it yet to see if the change workedbeeen busy with work. As far as warranty goes I have made many FORScan changes and dealer never cared or noticed anything different now if your brick something while changing it then I could see an issue Even if you read it to see what its set at that definitely will not harm warranty. Just been my experience hope it helps.
So now are you limited to the normal factory 95/96mph?Fixed! Thank you @HitIt for pointing me in the right direction.
Would you mind sharing how you changed it to 120mph?Here I thought it was bad at 80 MPH because I leg it sometimes so easily. I just changed it with FORScan to 120 MPH and i also set police mode haven tried it yet to see if the change workedbeeen busy with work. As far as warranty goes I have made many FORScan changes and dealer never cared or noticed anything different now if your brick something while changing it then I could see an issue Even if you read it to see what its set at that definitely will not harm warranty. Just been my experience hope it helps.
Y'all do realize that the factory tires on our trucks, and most of the popular replacements for that matter, are only Q rated (99 MPH)... hence the factory speed limiter being set at 95. A handfull are rated up to R (106 MPH), and only one that I'm aware of is as high as S (112 MPH, the 37x12.5r17 Toyo ATIIIs I just had put on my truck, I had to double take before I believed it, that same tire in other rim sizes is Q or R). Either way, seems like setting your speed limiter almost 10-15% over the highest rated tire you'd ever find for one of these trucks, seems a bit too Darwin Awardy for my liking.Would you mind sharing how you changed it to 120mph?
I've been trying everything In Forscan to remove the 95mph limit as where I live we have a road that has a posted 100mph (160kph) speed sign so I'd like to increase the limit to allow for overtaking and sustained driving at that speed.
I've had no luck with Forscan settings removing any set speed or even putting in a higher speed it's still locked. And I have no mykey enabled on my '22 350.
Interesting to see the 37x12.5 x17's are S rated (112 mph) and the 37.12.5.18's are Q rated (99 mph) - specs for both tires are pretty much the same! I have the 18's and have OEM limiter around 96 mph. The Toyo's pending size range with some Q, some R and some S, so not one rating for all.A handfull are rated up to R (106 MPH), and only one that I'm aware of is as high as S (112 MPH, the 37x12.5r17 Toyo ATIIIs I just had put on my truck, I had to double take before I believed it, that same tire in other rim sizes is Q or R).
| 37X12.50R17LT | 128S | E | BSW | 357010 | 8.0-10.0-10.5 | 73 | 16.9 | 36.5 | 12.5 | 3970/- | 65/- | - | 569 |
| 37X12.50R18LT | 128Q | E | BSW | 356010 | 8.0-10.0-10.5 | 71 | 16.9 | 36.5 | 12.5 | 3970/- | 65/- | - | 569 |
That is interesting! I can get my head around a larger tire having a higher rating given that the rotational speed is slower than a smaller diameter tire at the same linear speed. The difference between rim diameter is odd, though...Interesting to see the 37x12.5 x17's are S rated (112 mph) and the 37.12.5.18's are Q rated (99 mph) - specs for both tires are pretty much the same!
I was as baffled as both of you, the 37x12.5r20 is also Q rated, I had just assumed it was a typo on their website, and didnt believe it until I saw the "128S" molded on the sidwall with my own eyes. I have zero intentions of ever driving the truck close to that fast thoughThat is interesting! I can get my head around a larger tire having a higher rating given that the rotational speed is slower than a smaller diameter tire at the same linear speed. The difference between rim diameter is odd, though...![]()
Here are mine!I was as baffled as both of you, the 37x12.5r20 is also Q rated, I had just assumed it was a typo on their website, and didnt believe it until I saw the "128S" molded on the sidwall with my own eyes. I have zero intentions of ever driving the truck close to that fast though![]()
Until it isn't and things go bad!!!!If I want to pass, I don’t care what my tires are rated at. There is margin for them, not for me.
Things go bad if you don’t get pass. CheersUntil it isn't and things go bad!!!!
37x12.5r17 Toyo ATIIII want an s rated tire and speed limiter at 120
