SPE Full lock diff kit
LOL Altitude and airspeed are your best friends! You can trade one for the other to suit the situation. But you can run out of both in a hurry. Then you're in trouble.
Apparition, search YouTube for the Boeing 707 barrel roll.
The head test pilot was doing a flyby with the prototype at the annual Sea Fair during which the international association of airlines was also having a convention. The new plane's sales were very poor at that point. He did a unscripted barrel roll at about 3000' above Lake Washington in front of 200,000 people!
By the time he landed the orders were pouring in! Legend!
FYI, a barrel roll is a very simple 1G maneuver that puts zero stress on the airframe or engines. Some recip engines don't like it but jets don't care. A C-5 Galaxy could do one but then its pilots would be looking for new jobs.
Seen it. A good friend of mine is a fighter pilot and instructor he’s taught me a lot about planes.
also the speed check by the SR71 is worth a listen.
I also contacted another company that had a better kit, but they are not making it.
walter Burch <[email protected]>​
Tue, Feb 9, 7:39 PM (17 hours ago)
to me
Kit has been discontinued at this time sorry
Thank you
Walter Burch
www.AftermarketHQFab.com
6466 Windy Rd Ste B
Las Vegas NV. 89119
Office-702-202-1263
Fax-702-331-0116
[email protected]
i don't really see a need for locking the rear end above 20 mph. The only time i see a need for a rear locker is low speed articulated crawling. a rear locker is useful in the dunes or dirt at higher speeds but our trucks weren't designed for that. that's what the raptor is for. i couldn't imagine driving this truck off-road at higher speeds. It's pretty jarring at low speeds already
Just fyi,
I contacted East Coast Gear Supply to see if they or anyone else have a Detroit Locker for the M275. They do not, and advised it will probably be years before you see viable locker options for the M275 since it has only been on the market in super duty recently
Truetrac and detroit locker is available for the front Dana Super 60 in the Tremors/Super Duty
You are correct with a stock truck, and totally depends on usage. With my Fox / BDS suspension it is a good cross between the stock Tremor and a Raptor (sort of). In the Silver Lake Sand Dunes I like playing mostly in 2wd, because most any newer truck can go anywhere in 4wd. But you need to have wheel speed in 2wd, and with diff locked it starts reducing the power in 2nd gear because it thinks you are going faster than you are. Had some issues in 4wd too. My Raptor I could run thru the bumps at 60 to 70 with no problem, and with the Tremor have run same area 30 to 40 and it soaks it up pretty well. Last weekend ran out at Holly Oaks off road park on the track, and played in 4 low which really helped and made a big difference because it stayed locked until around 50mph, and did not have issues with any of the nanny's. I would have never been able to do it in 4wd with posi on. With the posi was able to toss it into the corners and get the rear to help steer me around the corners which was helpful and fun.
But again, depends on usage, wants and needs.
Yeah i can see that in the scenario you describe. I wouldn't try the dunes in my 6.7 truck because of the wheelspeed/ engine speed issues. can't rev the diesel like you can the gas motor. diesel wants to shift too much and would probably bog in the dunes. that and the weight
There seems to be a lot of confusion surrounding a ‘locking differential’ and a ‘limited-slip/positive-traction/posi-trac’ differential.
The locking differential locks the output so the wheels on the same axle turn at the exact same rate. Dangerous as shit on the road, where the outside wheel needs to turn at a different rate when turning. Consequently, neither wheel turns at the correct rate, and rear end comes around to say ‘hi’ to you.
All the others are limited slips. That’s all they do: Limit slip by sending power to the wheel with traction. No matter what the name is, they’re not locking differentials, even if manufacturers confuse the issue by publishing ‘lock-up’ rates.
The only limited slip the Tremor has is in the front. There is no rear ‘posi’. There is a locker only.
I drive my jeep on the street all the time with a spool in the rear. Very predictable and never had an issue. A Detroit locker that disengages and re-engages off and on throttle during a turn is less predictable until you get use to it. Being fully locked in a Super Duty at speeds above 20 mph should not be an issue but I can understand why they disable it.
In a light mustang this could be possible. In a heavy super duty, a full time locker in the rear is no issue. I had one in my 2007 F-250 (Detroit locker rear/truetrac front) in Minnesota for almost 14 years. I also had detroit lockers front/rear) in a 2004 F-250.
Lockers are the ultimate traction in a heavy super duty, rain, snow, mud, ice, dry...does not matter
Those don't remain locked on deceleration, once you start sliding and the diff remains locked when usually your wheels would be knocked each going different speeds trying to find traction but with the full lock on decel it makes it hard for either wheel to reach the correct speed and they fight eachother. This is why guys weld their diff solid to go drift. Letting off the throttle breaks it loose. I'm not saying your wrong but youre talking about something unrelated to an e-locker stuck on all the time.
I know firsthand about Detroit lockers. My old offroad truck was a 72 Chevy, Dana 60 front, 14 Bolt rear, both with Detroit lockers, on 42" Swamper TSLs. Also had an SM465 granny 4-speed and NP205 transfer case. I drove it on the road a lot because it was so dang fun. Sometimes the dang rearend would pop so loud when it locked/unlocked that it felt like I broke an axle. Years before, I had a Dana 60 rearend out of an old F250, with the spider gears and side gears all welded up into a homemade "spool" (Lincoln locker). Yes, it squawked tires all the time around corners, but it was 100% predictable, whereas the Detroit would go BANG and surprise me, sometimes making the vehicle "jump", although I'm sure the 42" tires and manual transmission exasperated that issue. I got used to it pretty quickly, but for street use, I'd rather have an ARB or some other selectable locker.
I wish the Superduty rear locker didn't have a speed limit. Not because I need it, but because I want it.
@Smindustries
Not sure why this response was gone when I went to respond to it, so I took screenshot of email...
Also, did not mean to say "lockers", as in a row of school storage cabinets (lol)...my phone did that and I didn't notice, so I edited it to "locker".
With all due respect, because you seem very knowledgeable, I disagree... And I'm not trying to come across like an @ss.
I understand what you are saying about marketing. But when under power, even with suspension fully articulated and a wheel 4' off the ground, a Detroit is locked. It pulls the tire that is in the air. Therefore it is a type of locker. Not a limited slip. A limited slip would most likely not pull the tire. Yes, it can provide some differentiation when off the throttle and wheel speeds are different, but as soon as throttle is applied, it locks up--Which is what gives it the handling quirks.
And I never stated that the Superdutys did not have a locker. I know it does, and know how to turn it on and off. I simply said that I wish it didn't have a speed limit. As in I would like full control over it, because I have the experience necessary to know how the truck will handle with it on, at any speed.
To the OP, I'm sorry for the derailment.
My 2007 F-250 has a detroit locker in the rear and truetrac in the front, for the past 12 years. My previous 2004 F-250 I had detroit lockers front/AND rear. The Detroit Locker, is exactly it's title, a LOCKER. It just has the ability to "disengage" when going around corner as long as there is not much throttle input. In that regard, it is not a full time "spool" per se. As soon as throttle input, the Detroit Locker immediately locks up.
Detroit Locker IMO is the best, because it disengages automatically (turns), and gives you maximum traction no matter what the situation. The ARB air locker is the next best but you have to have an air compressor.
If you have the 7.3 gas tremor, and you go off road a lot, Detroit locker in the front/with the OEM locker in the rear, you will have an unstoppable Tremor unless it's really really bad. You can't beat the auto/lock hubs on the super duty.
Super Duties are heavy and with 160" wheelbase, Detroit locker would be awesome in a Tremor (rear). The truetrac is the best in the front on a diesel.
I will switch to a Detroit locker whenever one is available for the M275. I'll put a truetrac in the front to replace the stock clutch limited slip
Can the Detroit Locker be used in the front axle?​
The simple answer is “yes”; however, conditions do apply. If used on-road, selectable locking hubs (not “autolocking”) must be present on the front axle. A vehicle with a locked front differential is not only unsafe to use on an improved road, it will also cause substantial damage to the vehicle and create extreme difficulty steering. The locking hubs must be in their “open” position for on-road use. For vehicles which only operate off-road, the use of selectable locking hubs is optional based on the operator ’s preference and driveline / steering system strength. For off-road vehicles such as rock buggies, monster trucks, and heavy equipment, the use of a Detroit Locker offers incredible traction enhancements. The use of either full-hydraulic or hydraulic assist steering is common in vehicles using an auto-locking differential in the front axle.
@Smindustries
A Detroit Locker is not a locker. A Detroit Locker is a torque-biasing limited slip differential that engages and disengages on its own. The operator cannot command it to lock. The operator is stuck with whatever the differential wants to do.
A locked differential drives the wheels on the same axle at the exact same rate under all conditions. That's why a vehicle with locked front and rear differentials does not turn. That's why they're unsafe on the street. If one were to drive a locked differential on a high-friction surface, such as roads, the drivetrain becomes mincemeat. The axle shafts corkscrew and the teeth get wiped off the gears.
Don't take my word for it: Call Eaton. They'll tell you that the Detroit Locker is a limited slip.
Edit: From Eaton's installation manual:
"Eaton’s Detroit Locker, also known as a NoSPIN, is a fully automatic, positive-locking, traction differential."
Eaton's E-Locker is a real-deal, bonafide locker.
On my 2007 F-250, I replaced the OEM hubs with Warn Free/Lock hubs, with the truetrac. What an amazing upgrade. Only down side, is if they are in the FREE , you have to switch to LOCK on the hubs then turn the dash selector to engage 4wd. No more dependency on the factory vacuum.
On my 2004 F-250, personally, I did not like the Detroit locker in the front. Although it was ultimate traction off road, the steering feedback was not the best (the detroit locker in rear which tended to "push" the front end through turns). I did install hydro assist steering which helped.
IMO.... 7.3 gas Tremor that spends lots of off road time: Detroit locker front/oem locker rear (detroit locker when available for M275)... would be a beast.
6.7 Tremor...Truetrac front/with oem E-locker or detroit locker (whenever it will be available).
This is best combo for these trucks based off my experience, imo. The truetrac is "seamless", virtually bulletproof, no parts to wear out, and 99% of the time will provide power to both wheels.
This is correct. Also correct, you really don't want a detroit locker on a street vehicle. I had one in my Bronco and it was dangerous in the corners or while otherwise turning. Especially in the rain. If you weren't careful on the gas in the turn, it would lock up and send you straight... scared the shit out of my wife the first time she drove the Bronco (had a lead foot) and she almost crashed.
Leave the detroit locker for off road only (then an ARB locker or similar is preferable) or the drag strip, where it really shines.
I guess the word "locking" doesn't mean anything, then. It's fine, I won't argue with you-- as you won't change my mind and I won't change yours. I understand the capabilities of a Detroit Locker and that's all that's important to me. I'll leave this subject alone.
