Solar System Build - F350 Diesel
I burned up 2 Ecoflow Delta Max 2000 with their kit ground panels.
Returned both of those and built my own system with the Victron unit and more mounted solar panels.
Have 800Ah of Lithium and around 1kw of solar (600w ground 400w mounted) now and can run everything for 10 days without sun,
That’s a massive system. Curious what you could possibly need 4000W of 120V for? Also curious who would want to camp for 10 days without sun :ROFLMAO:
Any thoughts on EPOCH batteries?
I have a Palomino SS550 truck bed camper. It came with a 100W solar panel and controller. Uses 2 blue top optima’s for storage. Im considering replacing the 2 battery setup for one or 2 EPOCH (or similar) battery and also adding another 100w or 200w panel.
The camper has a decent setup already but like others have said, build it bigger for future plans.
Built by roypow to their specs they claim. Roypow builds the powerurus I mentioned earlier (less feature rich though). All depends if the features and warranty in that epoch are desirable for the increased cost (including shipping) or not. Even if you are drawn to epoch decide if the marine battery is worth the extra cost versus their non-marine heated battery.
I think i am getting closer to my final canopy solar setup. Feedback welcome please?
4x 100w Renogy flexible panels operating in 2S2P outputting 200w @ 24v into the Victron 100/30 which will feed a heated/ insulated 302ah LiFePo4 4s batter bank. Might expand to 8s in the future..
The trucks 360a alternator will feed a Victron Orion-TR Smart 12/12/30 DC-DC for topping up on the road.
I will than mount my Xantrex ProWatt 2000w right beside (12") from the 302ah LiFePo4 which i am looking for a reliable 200a discharge BMS, likely the JKS B2A8S20P-HC
Have you dimensionally looked at this layout versus the top of your topper? Certainly doesn't seem like 4 stacked perpendicular along the canopy will fit [][][][] style. But perhaps three of them perpendicular with one parallel fits?
Again you may want to look at a residential panel, state side you can get a NEW ~400w panel for ~$250. You can get used ones even cheaper.
i am mounting them on a 52" x 82" K9 slim line rack. Its only temporary, i really purchased them to lay on the top of the Eezi-Awn 2200 trailer top tent when its open.
i am trying to find an arrangement to slide under the rack on a drawer slide type system when stationary,.it would also add some shade, i could put rotate down legs to support the corners . any suggestions for a way to occupy the ~available 50" x 81" with PV
i was concerned with wind interference with the flexible panels, more of a stationary type panel IMO
i can fit 4 100w flexible panels oriented sideways on the rack, they are ~47 wide and 20.5" wide so i will have ~ 2.5" strip on each side and a perfect front to back coverage.
when discussing LiFePo4 batteries.... current draw C0.5, C1, C3 and the BMS limitations seem to be a pretty big drawback when running 12v/120v inverter.
i can fit 4 100w flexible 100w oriented sideways they are ~47 wide and 20.5" wide so i will have ~ 2.5" strip on each side and a perfect front to back coverage.
If that layout works then great, mainly was pointing out you can get the same wattage for a fraction of the price in a smaller footprint if you aren’t over paying for 12v camper marketed panels.
I have 4x100w on my camper due to dimensional constraints, I would have happily slapped a 48v 400w single panel on my camper if it easily fit.
i was looking at the LG NeON 420w but the size is just too odd to fit 2x, i could add 1x under the rack on a drawer system, which will still let me use the rack for rack purposes.
This rack ~53 x 82"
please excuse the ram.. but i am planning to mount the above K9 rack on the A.R.E. MX HD canopy. I will remove the crossbars and fab up a direct mount to the 4x posts coming through from the under support structure. What i need is the dimensions between the bars so i can size the panel length. If i have the room I will nest 2x on top of each other, have one slide out to the left and one to the right. on Tracks like these.. Aliexpress link: Drawer Slide
images_gallery_are-hd-series-truck-caps_are-hd-series-truck-caps-gallery-3_w760_h500_cr_q75.jpg
Not sure what you are asking. If you are building your own batteries I believe the primary factor affecting C-rating will be the wiring between the cells and the terminals.
There should be plenty of BMS options out there that can handle 100-150A. It seems like most of the LFP manufacturers use aftermarket BMS modules. You may be forced to use multiple BMS modules in parallel batteries to get over 150A, though.
Not sure what’s local to you but there are options typically from 300-460w, typically ~40” wide and 5-6’+ long. If stacking then 5’ might work? Anyways just a suggestion.
I could be incorrect but i think the limiting factor is the mosfets in the BMS's, yes the solution is to run in parallel. my 2000w cont. 3000w peak inverter requires 158 ~ 166a at peak steady state load, surge would require 238a which will trip a BMS
FLA as far as i am aware doesn't have any such limitation.
Starting FLA batteries have a high discharge C rate of 10-30C while LiFePo4 have a 1C w. a recommended 0.5C which necessitates a larger battery bank for short high impulse draws.
If you are wiring your batteries in parallel then the current is distributed evenly across all batteries. In other words you will only draw about 50A per BMS steady state and <100A surge. It seems like most of the consumer LFP batteries support 100A, so it should be easy to find a BMS that will work..
just bought the batteries 8pc LiFePo4 310ah, i will build two 12 volt packs, one for a boat. they will each run a JBD 300a BMS and a 5a active balancer. I am looking forward to building a nice heated and insulated hard wood battery box. need to source some 12v low wattage heaters now.
