Silly Questions From A First Time Diesel Owner....
I did not get the supplemental heater, figured it’s an overkill for rather mild new jersey winters. But now i’m wondering, does it come on automatically or is there an extra button to turn it on if you get that option?
Comes on automatically and I recommend it.
Felt Electric makes a timer you can control with your phone, just picked two up for the Christmas lights. Pretty sure you can program it with the phone app. Worth looking into.
Thanks for the lead - I was just looking for options. Is it heavy duty enough for the type of current draw we are talking about?
@Vermonster this one is a little less expensive and still works great. You can control it from your phone as well.
https://www.amazon.com/dp/B07JB5TQS...&pd_rd_r=19fc2b8f-c61b-4c7f-a653-8b7543a6b2b2
Thank you very very much! I need to figure out what the draw is...I assume the block heater draws more than the Christmas lights, but maybe not. I have the ability to park the truck indoors most of the time, but having the option to plug it in and have it on a timer when she's out in the cold - awesome!
I did put this in my truck build too. Also the heated seats and wheel - it just gets brisk up here.
From my research, I’m finding it’s about 1000w or 9ish amps. Now that is from search engines and not from the manual. I remember a thread running on here last winter that discussed this topic but I can’t find it. I picked up a 15 amp digital programmable one at Home Depot last winter. I suggest finding the highest rated one you can find. They are relatively cheap. I’m in a garage but it’s not heated (yet) so when it gets super cold, I’ll set the timer for 3 hours before I need it and I’m good to go in the morning.
Thanks, Brotha! That's very helpful.
i hooked up my entire house using lutron casetta wireless system, maybe 35 distinct lights and switches in total. So when they came out with an outdoor switch earlier this year, it was a no brainer to add them into my system. This switch is heavy dutyX waterproof, fully sealed, highly recommended it, especially if you plan on expanding the integrated lighting system onto other parts of the house.
Thanks, man! I have a "smart house" as well, but mostly Nest, Kasa, Nexx, and Blink (with some random appliances). I will check these out!
I am going to grab it from the garage and check it out. I will post the info.
OK, it’s not Felt it is Feit and I have been using 2 of them and they do work very well. You can control everything from your phone and I have not had any issues. You can set a schedule/timer or just turn it on as needed.
Great info, guys.
DEF: I have a truck stop near my home that is nearly always serving it up on tap. It's kind of great because they also have On-Road Diesel, Off-Road Diesel (for my tractor), Refer (I don't need that), and all the non-diesel options.
I always get my DEF at my local Pilot truck island. DEF will go bad and it can cause issues with the truck. If you buy a jug, check the expiration date to make sure it is still good and use it before it expires. My Chevy came with a warning. Expired or bad DEF fluid could cause the truck to go into limp mode. Then require a full system flush....I assume my Ford is similar.
I read an article on the theory of idling vs. Running the truck cold. The summary was that idling is a killer for these trucks and they actually warm up faster by driving them. I don't think 5 to 15 minutes here and there will hurt the truck, but you definitely don't want to low idle for long periods. If you find you are idlingbs lot, setting up a high idle switch will help with longevity.
I currently use the Archoil Ultimate Deisel Kit that has fuel and oil additives. For winter running, Archoil makes a winter fuel additive that has an anti-gel agent in it. Does it help, I dunno. I do seem to be conserving DEF and my regens are pretty far apart. But I don't know what is normal for our Fords. My Dmax had a regen every 3rd fill up and I added DEF every 4 fill ups. I didn't run any additives in it.
Also, those warnings are there because some dumbass at some point injured themselves, the truck, or burnt down the house by plugging in the heater in a garage full of gas fumes, paint thinner, or who knows what else. It is like the warning on preparation H. Not for oral use....you know some idiot ate an entire tub and sued them because it didn't work.....lol
