Silly Questions From A First Time Diesel Owner....
1. I use Power Service in each tank of fuel if the temps are going to be cold, meaning close to zero. In NC, I have never used it but I keep a bottle just in case.(y)
2. No, leave it plugged in while remote start, will not hurt. The only way the block heater is damaged is if it is not immersed in liquid. To help control your electric bill, I would put it on a timer
3. Buy it in bulk as needed at a truck stop. I never buy it by the jug, more expensive plus more trash for the landfill.
4. Wet stacking is not an issue with today's diesels. I would monitor the condition of the oil and possibly reduce the amount of time between changes in the colder months.
5. I have never used one, lived in KS for years with trips way further north in the winter. If the thermostat is working properly it will maintain the engine temperature. If I lived in Alaska, I would probably think differently.
Dutch061 , LongBedTremor, and Fordguy74656 are spot on. Been driving diesel straight trucks for 27 years and always have used Power Service ( white bottle) and have never gelled up. Don't let anyone talk you into Howe's. Always buy fuel from high volume station. Fordguy74656 has a very good point of saving receipts. Had this happen to my 2010 where I noticed fuel was low on the way home one day and stopped at a station I normally never used. Truck sat 10 days before driving again, and the fuel was full of water. Cost that station $10,000 to replace the entire fuel system of my 2010 Super Duty! Yes they paid because they knew they had water intrusion. Take care of your fuel, and truck will take care of you ! Congrats on finally getting a build date @Vermontmaster!! I wish I had one!
Nostalgic for people from the northeast.
More of a Midwest thing (I know from experience)... Nor'easters need a pot for their spoils - 🦀, 🦞
Of course both regions are in a northeast-ish vector from you so maybe my point is moot.
One could argue where I'm from in the northeast is actually more like the midwest. So you're probably on to something here…
I remote start it 5 or 10 minutes before I leave never had any problems even in the snow The rapid heat supplemental cab heater gets the inside of these trucks warm until the engine kicks in
So how good does the supplemental heater do when its like 20 out? I have it just trying to gauge how long till it gets warm.
It passed the wife and kids test it’s not burning hot but it gets it warm it’s like an electric coil inside the air duct it comes on automatically it’s warm within about four or five minutes running
DEF freezes at 12 degrees F (which is -11 degrees C for you Canadians in the house). If the truck is not running, DEF will freeze at this temp whether its in your DEF tank or in a jug in the back of your truck. If the truck is running, there are heater elements that keep the DEF in your DEF tank from freezing. When you shut off your truck, a pump activates to clear the lines of DEF, and pump it all back into your DEF tank, where it can safely freeze. If the pump fails, your DEF lines will freeze and things go bad from there. DEF in the tank can freeze and that's okay. Once you start your truck, the heater element warms the DEF in the tank, and once its all liquid, the pump will send it off to your exhaust system so it can do its thing and screw-up an otherwise great diesel engine :p. The noise you hear when you shut off your truck is the DEF pump, clearing your DEF lines so they don't freeze (that, or its gasps from the crowd at the sight of a beautiful Tremor).
I love my rapid heat as my first trip of the day is short. Finding out how to properly use this function is basically non existent except for vague comments on the internet and a couple of notes in the manual. The rapid supplemental heat doesn’t work when your climate settings are on auto. It only works when you use the climate manually. What I have found best is to put it on the chest vent manually. The manual says something about turning the heat to max but I have mine set at 68-70 and it heats right up. It seems to also work on floor vent too, but I find the chest vent better at blasting heat to the kiddies in the back.
I love it, people ask questions, are referred to the manual & then when the Manuel is quoted people say it’s written by lawyers, totally a catch 22
to be fair, this is the quote from the manual:
  • Make sure the system is unplugged and properly stowed before starting and driving your vehicle. Make sure the protective cover seals the prongs of the block heater cord plug when not in use.
The manual also states this in the block heater section:
  • Make sure your vehicle is parked in a clean area, clear of combustibles.
It appears that based on the manual one could start the vehicle, just not "start and drive". To conclude, based on the manual, that you will damage the heating element if you start the engine with it plugged in doesn't make much sense. And I agree that it really doesn't make much sense technically, but I'm far from an expert.
Similarly it doesn't make much sense that you will damage the heating element if you plug it in while parked near combustible materials. Furthermore, parking in an area clear of combustible materials is a pretty silly statement - "hey, park this big chunk of plastic/rubber/fuel in a place where there isn't anything that can burn".
Manuals are great, but can sometimes be misleading.
So you live where people never plug their vehicles in indoors or in areas full of combustibles during the winter I’m assuming
Have talked to a firefighter in Warren MI as well as one from Bismark ND and you would not believe the number of people who plug in trucks when it’s really cold indoors or in areas full of combustibles or how many fires they cause.
Not to mention that you know that Ford has been sued by somebody a few times for doing exactly what they tell you not to do if they are that specific
Thank you, sir! I look for a timer for that heater - good idea!
Felt Electric makes a timer you can control with your phone, just picked two up for the Christmas lights. Pretty sure you can program it with the phone app. Worth looking into.
Yeah, not a lot of block heaters in Houston, TX. I did spend over 20 years in a cold climate, actually had a block heater in one of my cars in high school. People seem to do more stupid stuff related to cold weather here than up north, believe it or not.
I see your point about gasoline and the like, but the manual says "combustibles" which includes a lot more stuff, including much of the truck itself. So according to the manual don't plug in next to a pile of firewood, a garbage can, some fallen leaves, your house... Clearly, as I think you agree, the only purpose of having this in the manual is to prevent Ford from being successfully sued if somebody is reckless and starts something on fire while using the heater.
Back to the issue at hand, the manual says to unplug before starting and driving, but doesn't say why. This statement was referenced as possibly supporting the idea that you could damage the block heater (or engine?) by starting the engine with it plugged in. Will you damage something if you start your engine with the block heater plugged in? My basic understanding of block heaters and common sense says probably not. But if you drive off with it plugged in there's a good chance something bad will happen. Not really a catch 22.
Thank you for explaining how the truck works with DEF in low temps.
