Ryobi Cordless Air Compressor
Flourman
Colorado
2022 F350 Lariat Tremor
2019 Beta 300RR
Didn’t want to pony up for an ARB or VIAR right now and I thought this one might be a suitable alternative. We’ll likely get an ARB once the wife’s Bronco comes. This one might fill the gap. Also will help with the odd ball stuff while camping too. Watched some YouTube videos on it and it seems like they are decent little machines for the money.
I'll have to check that out. I am already committed to that platform and have been very happy with their products for the most part. I have the handheld unit and have used it to air up my garden tractor tires (26x12.50) and it works quite well.
WTF $129 and no battery.
"Battery and charger sold separately"
Charger and battery is another $100
Also, BTW, the battery charger probably doesn't work with the onboard AC ports.
I just checked one of the latest single chargers I have and it is rated at 120V/60W. I have used the onboard inverter in my previous F150 for this and it worked fine. Or are you thinking the quality of the sine wave is an issue?
Not sure if this matters since it is going back to DC... Have to go back and look at my electrical theory.
Same here. Been running the small one for a while and it’s super handy for things like Motorcycle and bike tires. I’ve got my camper rigged up with a separate charger off the inverter (we boondock almost exclusively).
Almost all cordless things are like that now. Get started on a platform and go from there. $129 isn’t a bad deal for what it is. **Edit, just checked and it works fine with my older charger. It’s only 85W though.**
I think I have three different styles of chargers... I keep one of the smaller ones in the truck since it doesn't take up much room:
Many others have complained that the onboard AC outlet won't charge their phone because of the fact that it is not a true sine wave inverter. I guess you just have to try it.
Personally I think you would be much better off with a onboard compressor even if its just a Viair compressor. You can get a continuous duty cycle 450C for $225.
Personally I think you would be much better off with a onboard compressor even if it just a Viair compressor. You can get a continuous duty cycle 450C for $225.
I don’t disagree. This was bridging the gap. I’ve got full intentions of getting an ARB twin compressor in the future. Heck, almost bought the Ford Performance ARB yesterday but no one within 60 miles had one in stock.
Agree as well... I honestly didn't think they were that affordable but have not done much research either! Long term if this is something I will utilize on the truck will have to look into these. For now all my tasks are multi use/location.
Thanks for the info!
It depends on how big the battery is. 9 small tires with a 4AH battery, more with a 9AH battery.
4AH batt = $79
9AH batt = $159
This guy filled a 21 gal tank with a 9AH battery. Took about an hour. 120PSI
4AH batt = $79
9AH batt = $159
I watched all of those last night. It’s a decent compressor but it looks like I’m not going to change your mind (didn’t plan to anyway).
Just ran my own test. Dropped a tire to 25psi and aired back up to 60psi. 13 minutes.
I tried A few different ones the 2.5 Dewalt seems to be the best went with the dewalt have all the tools already The first one with the jumper cables died right away it’ll only air up a air mattress now that Ryobi you got looks like a nice set up 👍🏻
View attachment 33667View attachment 33668View attachment 33669
Don't get me wrong, I like the concept and I am sure the Ryobi is a nice compressor. I guess I have a different set of needs for an air system.
I have a continuous duty compressor and a 1/2 gal air tank mounted in the bed of my truck. I use the air for an air horn, for airing up the tires after the trail and to maintain the trailer tire pressures. I have tried many different setups on my Jeep and have tossed a good bit of $ in the pursuit of something that works well for me.
I just completed doing the same test that you did. 25psi to 60psi in 5:35. BTW, I started with a full air tank.
We have the small Ryobi and I can confirm it took a fully charged 4ah battery to take a single tire on the Tremor from 39 psi to 58 psi. One battery per tire and about 18 minutes each! I have used this air inflator on regular car tires and it seems great for occasional usage but I wouldn't recommend it for the Tremor.
I have thought about trying their battery compressor with the tank thinking it might better. I would be interested to know if the results are better.
Very nice system. I’ll be upgrading at some point.
I used my Milwaukee chargers in my f150 AC ports all the time. They worked fine
