Rust in tank?
Changed out the tank to the SB and there was for sure metal in my tank but it looked like flakes of painted metal and maybe sand. Closeup and zoomed out.
View attachment 149028View attachment 149030. Until the DCR I will continue to monitor it. I cleaned everything I can and used all new fuel so finger crossed!
Did you run a magnet in down in there?
How hard was it to put the S&B on? I would like that option.
I did run a magnet I didn't snap a picture. I still could later today as I have not dumped the tank yet, it did not pick up much up at all but the painted flakes I was able to grab one with a swab. The other thing I did was a diesel fuel/tank test on both fuel and swabbed tank both came back clean so I have no idea.
As far as the install on the SB tank a lot easier than I was anticipating. I had an extra set of hands so that made all the difference. The hardest part was the getting the rubber hose from the fill neck off. That took lowering the tank a bit getting my hands on the rubber hose and my helper pulling the fill neck. Also the hose clamp was put on before the bed was attached so it was not easily accessible and took some patience.
Was able to change everything with forscan and so far so good. I also did the HSM lower filter upgrade and that was overall easy as well. I put the tank on first then did that one as it was easier to route the hoses.
Nice work! Hopefully this sand/metal is all behind you.
Your filters likely saved you from the contamination doing harm. I too am going to stay with the CP4 along with a DPK, the CP4 may never need replacement.
Yes, I think that to *fingers crossed*. I checked both filters and nothing but fuel in both. The HSM kit takes a Donaldson filter that I have read is a 3 micron absolute. With that theory I am hoping only the best fuel will get to the upper filter and keep the CP4 safe until I can afford to make the change to the DCR with both time and money.
