Do you spray it in the openings or take apart before spraying? My driver side is opening slow as wellMay need lubricated as well. The WD40 silicone spray made my mirrors much better and stopped the squeaking.
Too much work to take the mirrors fully apart. Unfortunately, I think I will need the Gruven replacement metal gears and motors. That will be a pain to do.Do you spray it in the openings or take apart before spraying? My driver side is opening slow as well
Good point. I notice the mirror acts up in the hot afternoon vs am. I will try with motor running as well. I used the silicone wd-40 as well.Bit of an update: the armature in at least one of the folding motors on my driver side must be degraded compared to new. I’m sure the TX heat doesn’t help. The motors are low quality anyways, like a toy car brushed motor.
I noticed that it will fold much more easily/perfectly with the engine running (higher voltage). When the truck is shut off, it’s weak and sometimes won’t completely finish folding and stops. So, for now, I’m just folding them with the push button myself only while the engine is running.
A solution without having to order new motors from Gruven parts would be to create a voltage boost circuit so the motors get a little more voltage.
I learned that the spray doesn’t really get to the motor and gear area at all, as it’s pretty well contained and buried; it just lubricates the hinge points.Good point. I notice the mirror acts up in the hot afternoon vs am. I will try with motor running as well. I used the silicone wd-40 as well.
Same here, having to manually help the mirror with my hand is quite annoying. Changing the motors out isn’t too easy of a job either, if I were to get the Gruven ones with metal gears.This is aggravating! Mine works perfectly when it’s cooler or cold out. Once it gets hot from direct sun my driver side mirror doesn’t want to work properly. I’m guessing something gets warped enough in the heat to cause enough friction to stop it from functioning. @BroncoHooves might be on to something with the mirrors needing a little bit more power. I only fold my mirrors automatically when locking so the motor is off. Lately. I’ve been helping my driver mirror open and close by gently pushing on it. I made an appointment for the wiper arm recall and mentioned my mirrors and of course they said 3-5 days to check it out. That’s not gonna happen anytime soon. Especially for something I’m sure they will say is fine bc they can’t replicate it inside a shaded climate controlled shop.
It's the motor in the mirror. Common issue that can be fixed with aftermarket motors.Just had my driver's side replaced for same issue, dealer ordered about 3 months ago. It is an issue with mirror itself, probably inferior parts.
My truck is having the same issue routinely I have to roll my window down press the auto fold button and assist it in opening outward.....did they ever determine what was causing your issue?My truck is currently being inspected at the dealership due to an issue with the driver side mirror, which is having difficulty folding outward intermittently. I’ll keep this thread updated with the outcome.
Did you use the water resistant product? Curious as that seems like it may be the appropriate solution.May need lubricated as well. The WD40 silicone spray made my mirrors much better and stopped the squeaking.
This is great information! Thank you very much for doing this. Curious, where and how does the electrical make the connection to the motor? Is it simply a "touch" contact or are there wires attached to the motor through a harness?So, I took one for the team and ordered a busted, but complete, mirror from a wrecked '22 Super Duty to see if it's even feasible to risk replacing the motors in these. All but one gear is metal in the two folding mirror motorsConfirmed it to be a black, glass fiber reinforced Nylon gear.
Also note the leaf spring as well which allows the mirrors to be manually folded without breaking anything.
I suspect the cheap hobby, brushed motors are the issue and not the gears.
Taking the mirrors apart isn't the easiest thing and some of the arm shell clips broke, so I'm not even sure I recommend this.
Bonus picture at the end of reply showing how the single telescope motor and geartrain works as well.
There is a friction fit connector with two male spade terminals that plugs into the motors with a rubber ‘seal’ around it. I didn’t get a pic but can take one tomorrow.This is great information! Thank you very much for doing this. Curious, where and how does the electrical make the connection to the motor? Is it simply a "touch" contact or are there wires attached to the motor through a harness?
Reason I ask: If the contact oxidizes, it may be the issue. The brushes should not (in theory) be the issue since they are generally carbon rods. I've troubleshot instruments that go intermittent and sometimes caused by poor contacts. (Even gold contacts) It's very common, especially if the contacts are not protected from debris such as dust. Possible next step would be to measure the voltage at the motor during operation, to see if it drops. I still wouldn't count out a weak connection in the wiring at this point.
Ironically, my truck was doing this for a while and now seems to have cleared itself up though admittedly, I soaked it with WD40 at one point several months ago. (Not sure if it even penetrates in) It's going on over a year now and doesn't hang up anymore. I do have them in auto fold, so they get exercized very often.
Thanks again for posting this, it really helps to get a visual representation. Interesting that the contacts do not appear as plated, and the motor contact surface appears to be copper. Two dissimilar metals in an extreme temperature and humidity changing environment. What could go wrong? (Galvanic reaction, leading to high resistance contact.)
The connector prongs are plated. There is a vertical witness mark where the plating is scratched from pressing into the motor.Thanks again for posting this, it really helps to get a visual representation. Interesting that the contacts do not appear as plated, and the motor contact surface appears to be copper. Two dissimilar metals in an extreme temperature and humidity changing environment. What could go wrong? (Galvanic reaction, leading to high resistance contact.)
Silicon dielectric would be ideal in this situation. If mine ever acts up again, I may try to disassemble and fix it.
