Ride quality control
That’s a bummer. I think I’ll be considering it anyway. Coming from a 200 series cruiser I know the ride quality is going to be noticeable, haha
+1...just get them put on, it makes a big difference especially after the 1,000 mile retorque and cost is minimal.
Thanks. Do you know the specific part number? Their website hasn't been working properly for several days now.
Any long term experience with the sulastic shackles out there?
I've had them installed for roughly 2000 miles. Hardly long term, but I did ask the inventor/owner a few questions about longevity. He was pleasantly candid. He said if problems are going to occur, they always do so in a specific way - it has something to do with the rubber within the mount - he said if there is going to be a problem, it will surface within the first 18 months, and they will warranty the issue. Once that general window has passed, he said issues were exceptionally rare and the expectation was for them to last up to 15 years.
Bags aren't going to help with the capacity, just the sag.
I've heard this same thing said many times. It doesn't make sense to me. The bags are carrying a varying amount of weight depending on the pressure within the bags. Taking my thinking to the extreme, Kelderman systems and semi air bags carry a lot of weight. If one installs progressive leaf springs and loses 1,000 lb of capacity, why would air bags not be able to make up that 1,000 lb of loss.
It's really simple, it's all about efficiency. I know sag has a role to play, but to cleanly address your point, I'm going to ignore it entirely.
The bags are there to split the load carried by the springs and the shocks and to rigidly direct that load to the axle. It is the diffusion of force that is the relevant characteristic. Take my truck, full Carli pintop, deaver leafs... The works... By installing a high performance system, I've lost a significant percentage of my towing capacity to suspension components that are more responsive, more pliable, but otherwise individually incapable of bearing the same capacity as spec'ed by the factory.
So, what has changed? The frame is still capable of the same load, my gooseneck has not been downgraded, nor has my hitch, or my axles... Nonetheless, I cannot tow as much as I could before, however, after adding a bag system to my rear, I can. What has happened is that I've simply reduced the load placed on the suspension components and distributed it across the frame, through the bags, and down to the axle. I have restored what was lost by increasing the efficiency of the distribution, but at no point have I augmented the natural capability of the chassis itself. At first glance it might seem like artifice or nuance, but it is an important distinction to make.
I mean, that's about it. The truck can't carry more than it used to, it's just that due to the increased efficiency the bag system introduces to the suspension, I can now run lower capacity but more responsive components while retaining the ability to pull what the truck was originally designed to pull.
Edit: I reread the post you were replying to, and despite knowing what I've just written, I was wrong... plain and simple. What I meant doesn't really matter, I really suck at being pithy.
Apologies for any confusion I've caused.
While you did misinterpret @OverTheHill, your post does very eloquently address why air bags don't add capacity beyond factory, which is a common misconception. So well written, just wrong timing. :)
And I would say that capacity is determined by the sticker on the door by Ford. GVW for the truck will not change no mater what you do to it.
Wow….I’ve used bags for years to allow me to safely carry heavier loads than my stock truck could carry without bags. They do not change the factory load ratings, but they are useful.
It's crazy what people will try to argue simply for the sake of argument.
If you've been using the bags for years and have been exceeding the rated limit, all that you've demonstrated is that the rated limit is not a valid indicator of the mechanical capacity of the suspension or the chassis. Using bags to load in excess of the mechanical capacity of the vehicle would inevitably result in failure. It is by its very definition, not safe.
The principle is valid, no matter the nuance of the sticker on the door jamb,
If I want to carry a load (that’s still under the factory rating) that causes my truck to sag….more than I want it to….I’ll add a little air in the bags and it no longer sags. Doing that is totally safe by anyones estimation. In fact it is safer because my headlights aren’t blinding on coming traffic.
