Removing Pro Power?
V8Notch
Tremor Buff
HTX
2024 F-350 Lariat 7.3
In another thread someone pointed out the amount of under seat room the Pro-Power setup takes. My 2024 came with Pro-Power. I don't need it, I'd rather install a 12v alt and an aux battery. That way I would have 2 completely seprate 12v systems.
I'd like to the leave wire pro-power hardnesses in place and just unplug them both ends (alt and big orange plug by inverter). Do I need to do anything else? Is it going to sent warning messages?
My bad.... 😉🤣🤣
Just an FYI i believe it was mentioned in another thread the Pro Power runs on a different voltage than the truck battery. It’s 24V or something. I ordered mine without for the above reasons.
@Chadx I hate to keep pinging you but if I remember you were the one talking about it.
Let us know…
Let us know…
Yes, the pro power is a 24v system. I want to take out the batteries and inverter. Then replace the 24v alt with a 12v and run new wires to a 12v aux battery.
Resurrecting an older thread here, but has anyone removed the Pro-Power for service? I need to pull it to complete my sound deadening project.
Is it as simple as pulling the battery connectors under the hood and under the passenger rear seat and then start unplugging and unbolting, or is there anything else I should know.
Thanks.
24V alternator?
While a higher voltage makes sense to get amps downstream, I was under the impression that things like the ProPower feature, or the Ford factory (dealer) install of a particular WARN winch, for example, required the dual alternator setup... but those are simply a 250 amp and 160 amp 12V combination to output a maximum 410 amps.
24V alternator... this is a completely different arrangement, and while a surprise, does make sense considering that system's output. It's halfway to that F150 gasoline/electric hybrid system's output, I would think. I never dove into that rabbit hole.
Thanks.
nothing in the service manual for removal, but lots on trouble shooting
it was interesting to see they say it is a pure sine wave
