Remove cab wall exterior felt insulators without removing bed?
BroncOh
โ€Ž
Tremor of the Month ๐Ÿ†
Tremor R&D ๐Ÿงฐ
Founding Member ๐Ÿ“œ
Meetup Organizer ๐Ÿšง
โ€Ž
USAF Vet
My cab felt insulators (located on the outside of the cab wall, between cab and bed), are starting to peel off.
I read on another forum they make road noise when they start to peel. On that forum, someone mentioned having to take the bed off in order to remove them, so I figure I would post here to see what ideas others may have in order to remove them without having to remove the bed from the frame.
My initial idea is to use a wide and thin piece of spring steel I have in stock as a 'knife' of sorts, hoping it can get between the felt and the cab and scrape it off. I would do it from the top side, as the cab vents on the bottom side would obstruct the spring steel.
Maybe you can get a long piece of plastic instead of steel? I would be afraid of scratching and gouging the back of the cab by using spring steel.
What type of road noise? Felt making noise between the cab and bed, really? Why not just use glue to make sure it stays on and doesn't continue to peel. Some of the ideas people put forth are bordenline โ€ฆ.taking the bed off to remove felt or using steel both sounds extreme for something which someone on the other forum mentioned as a potential problem to begin with.
How would one apply glue there if one can't remove them.
The sound issue is a matter of the mass and density of them thumping against the back wall of the cab.
Hoping the one that's in worse shape just falls off on its own with the 'colder' season coming up, as long as it doesn't land and sit on the DPF and cause a fire. ๐Ÿ˜‚
+1 on this concern as well... what could this mean for rust/corrosion down the line? Don't think they generally need to salt the roads in the winter in Austin, but it sure is humid most of the year there. A couple weeks ago, I had a new grill where the powder coat wasn't done well and an exposed spot started rusting after a week outside (covered and during a warm week with no rain).
Why the need to remove? Depending where it is peeling. If it is on top where you can access with your hands, simply put some glue on a stick and press against the cab wall to keep from peeling further. Unless iโ€™m not understanding the issue. I looked at my felt piece last night, thats what i would do if it started peeling.
It's peeling in the middle and is basically taco shaped.
It is an aluminum cab, so no concerns of rust. :) Though don't know if there's other corrosion concerns with having gouges in the paint. Aluminum does oxidize, so might result in oxidation under the paint and the paint peeling?
The exact thing started happening on my 17 F350 work truck. Going down the highway it sounded like I had blown a tire with a hell of a drumming noise. Was able to reach my hand in and just yanked it out. Of course, I have a service bed on instead of the regular truck bed.
I had the peeling issue with my 2019 250. The dealer pulled the bed off and fixed it under warranty. I dont know if they installed new or just reattached the existing felt. I never had another issue with it coming loose.
Hmm. Taking the bed off just isn't a scenario I can do unfortunately, warranty or not.
I think I may be able to fit a long screwdriver in from the topside. Retrieving it may be another challenge if it falls and wedges itself on top of the cab vent.
I think that screwdriver handle would be thicker than the opening or i would hope so. Why do they put felt there to begin with, i couldnโ€™t answer that when i first saw it. My only guess was to collect water and keep that space in between bed and cab moist:-)
I think that screwdriver handle would be thicker than the opening or i would hope so. Why do they put felt there to begin with, i couldnโ€™t answer that when i first saw it. My only guess was to collect water and keep that space in between bed and cab moist:)
Itโ€™s there for the assembly line is all; keeps the bed from hitting the cab.
I think I came up with a new game plan for removing them. I'll use some braided fishing line and a person on each side of the truck, and we'll cut through the adhesive glue. The fishing line can get right against the cab easily.
