- OP 🔹
- #21
Other than a few hardware items I need to order for the Noco inlet (stainless black oxide screws), all of the cosmetic things are either on order, or are delivered and ready to go.
What does police mode do?Great looking build! Definitely following!
And sure enough after reviewing your mod list, I'll be promoting some of my mods out of the backlog:
Also made me realize I need to think through Forscan more completely. I've been de-prioritizing it in my mind, but should be considering what I want to do. Definitely taking from you:
- Black vinyl wrap tailgate handle.
- Black tailgate letters.
- Noco block heater inlet.
- Police mode
- Minimum tire pressure
Prevents the truck from being shifted out of park without a fob present.What does police mode do?
Damnit, I envisioned being able to pull someone over and say "license and registration, chicken fucker!"Prevents the truck from being shifted out of park without a fob present.
Contrary to popular belief, it doesn't make you a policeman.
Where is it in the instrument cluster menu? If it's not, then the point is, Forscan is still needed to activate it.Police mode is already on the 2019 + trucks. My 2017 did not have it but my 2019 and my new 2021 has it.
That's a good name!Truck name changed to Red Zeppelin™ until I can find something better.
Why not carry a lithium battery booster? It’s so rare that I have to jump start a carAnyone know of any extreme high current, flush mount connectors I could use for jump starting?
The Anderson forklift battery connectors are 350 amp I think, but probably won't work.
Good idealithium battery booster?
I just ordered a set also. Hope I don’t screw them up trying to put them on…Tufskinz arrived today. Gloss black for hood and gloss black for glovebox.
I would recommend that you move the Jimmy Jammers up on the list of things to do. These trucks are ridiculously easy to break into.This will be my 'build' thread. Until I can find a better name for the truck besides Red Zeppelin, it is what it is.
Truck scheduled to be built next Saturday.
Immediate Mod/Cosmetic Items:
Future Items:
- Husky X-Act Contour Floor Mats for OEM vinyl floor - Front and Rear
- V1-Cut.com door sill protectors - non letttered/blank.
- Tufskinz Gloss Black Hood Insert Letters
- Tufskinz Gloss Black Glovebox Insert Letters
- TVDVinyl Gloss Black Tailgate Letters
- Black Powerstroke and 6.7L badges.
- Paint exhaust tip black
- Noco Block Heater Inlet
- Stahlbus No Mess Oil Drain for first oil change
- CravenSpeed Stubby brand antenna
- Weigh Safe aluminum 3" shank 8" drop hitch
- Peerless G80 1/2" Black Hammerlocks
- Paclock stainless hitch pin lock
- McMaster Carr receiver tube end plugs
Forscan Mods:
- Flush mount Anderson battery terminal for jump starting other people without popping hood. (Probably locate next to Noco block heater inlet)
- S&B 60 gallon fuel tank.
- Odyssey Extreme Group 65 AGM batteries.
- Retrax Pro MX with stake cutouts (for eventual RTT/rack setup)
- Putco rack
- Onboard air compressor
- Jimmi jammer hood kit
- Jimmi jammer front and rear doors kit
- Custom developed Diesel fuel and DEF locking caps for a product idea to sell
- Bambi mode
- Police mode
- Auto fold mirrors (maybe)
- DPF %
- Turn off all nanny chimes
- Tire psi minimum change
- Operator commanded regen
