Recalibrate fuel tank size
S&B needs to step up to the plate on this or I see them
reaping their just desserts of bad publicity. jess sayin'...
Finally got a call from the dealership today and said the pcm is fried. Need a new one and $1700 it’s going to be fixed I pray. Not covered under warranty either because it’s not a Ford program that I used to try n recalibrate tank size.
That doesn't sound right? Isn't it programming the BCM or dash just to change the distance to empty? I guess we'll see....
I think the potential issue was brought up a few posts ago - did the previous guy try to use the EZLink for some other tune install or update that wasn’t supposed to be there. But unless S&B can document some kind of QA procedure when an EZLink gets returned prior to be sent to the next customer, they may be liable here. But, if they do show they check it and prepare it for the next install, I can’t see how they could be on the hook for this. I think the bad PCM is probably totally coincidental. Just unfortunate it cooked out at the exact same time the tank info was being recalibrated. Crappy situation
I’d bring that to S&Bs attention. That’s messed up
I have and they said that they don’t Have any skin in the game. They just loan it out as a courtesy for buying there tank. I’ve been in contact with Ezlynk we will see but after it’s said and done. I’ll be out $2400 bucks and 6 weeks without my king. 😝😝🤮🤮
I already returned it to them because they charged me the $530 bucks and knew about the situation so I called and they reimbursed me now but wanted it back because the dealership needed it but S&B said it was already off to the next customer I’ll be waiting to see if we see this situation again if they find the forum
I already returned it to them because they charged me the $530 bucks and knew about the situation so I called and they reimbursed me now but wanted it back because the dealership needed it but S&B said it was already off to the next customer I’ll be waiting to see if we see this situation again if they find the forum View attachment 47289View attachment 47289
I just wonder if they document some type of QA procedure between customers, to ensure the program is good to go for the next person. I’d try hard to be on a list to get that back from them to prove, one way or the other, to the dealer that it wasn’t the EZlynk that caused this. Totally sucks
Slightly off-topic but still related to tank recalibration...
A friend just had a larger tank installed and the dealership told him that over the course of two or three tanks, the truck will
re-calibrate on its own. They stated they've installed many after market tanks, and they never recalibrate as the truck will "self learn". Sounds fishy to me....
I guess what could happen is it starts reporting a way better mpg? So the DTE gets more accurate but the mpg is reported as 40?
I can't imagine the logic is that robust. DTE would be based on MPG compared to known tank volume. I don't see how the truck can self-calibrate without storing tank volume somewhere...
I'm thinking for this to work then mpg is calculated based on the assumed tank volume. So the tank is 34 gallons, the float reader moves X amount over a mile, then the mpg is calculated as 18. Then the tank gets upgraded to 60 gallons, now the float moves half as much for the same mile, so mpg is doubled and the DTE has been doubled as well.
But you're right - the mpg is probably not calculated based on the position of the float reader. But I can't think how else the truck would "learn."
They changed the PCM and ordered the BCM. Went to dealership this morning. Said it will be in on Wednesday??? Just not sure when they going to get to it. Going on two months almost without my truck. 🤮😝🤮
Sounds like they are just throwing parts at it? Hopefully they aren't charging you for the PCM if it didn't help?
Man at this point I’m not sure how much I’m gonna be in this crap. Nothing is covered under warranty because of the aftermarket EZ Lynk I can plugged in to calibrate tank size. 🤷🏼‍♂️🤷🏼‍♂️🤮
Any new news?
Any new news?
Update. I got my King back today!!!!!!! Finally 😝😝😝. They finally contacted Ford engineering on Monday and she’s good as new with 60 gals under her. Said it’s back to stock. Went n filled the King up n changed the oil and installed my dual Fox stabilizers on this afternoon since I’ve been watching them sit for almost 2 months. I’m Happy 😃
Awesome! Did they say what the problem was? Doesn't sound like the PCM was bad? Was it the BCM?
How did they calibrate the tank size? Factory tool? Sorry for all the questions
Was thinking the same thing!! And how the hell is he getting 903 miles on a tank??? I can only get like 784. Same 60 gal tank and same 6.7.
