Recalibrate fuel tank size
Someone recalibrated your truck when you had the S&B installed, otherwise your fuel tank and DTE wouldn't display properly. That's typically done via Forscan, although I don't know how a Ford dealer would handle the re-cal (they won't use Forscan as it's not a Ford product) if they installed the tank. EZ Lynk is supposed to eliminate the need for Forscan.
Check out Facebook. There is a group for Ford techs only that use Forscan. I was granted access and in reading their posts, they complain how bad the ford products are and that they will be using Forscan more often.
Well I installed my S&B with no issues and ran it for a few weeks until S&B sent me the EZ lynk to recalibrate my tank size and when I did it one Sunday morning on January 23 it not had any throttle since and been in the shop and then at a Ford dealership now till this day. I missed the last weekend of deer hunting and borrowing a truck to fish a tournament this weekend. This sucks baddddddd. Bout ready to buy another truck. 🤮🤮🤮
That sucks! Does the dealership have any clue on what the problem might be?
Hard to see how the EZ lynk affected the BCM so drastically that it won't run although anything is possible with puters. As noted my shop had probs getting the DTE dialed in but S&B fixed it and it has been flawless as well as extremely accurate.
What did S&B do? My DTE hits 50 miles, I go fill up, and it’s consistently had 7-8 gallons still in the tank. I’d like it to be a bit more reflective of what’s actually in the tank if possible.
I wasn't in the loop - way above my pay grade. While towing through
N AZ last Oct I didn't want to stop at sketchy gas stations on the res so pressed on towards Flagstaff. When I finally pulled into a truck stop my DTE was showing 11 miles! There was about a gallon or two left so whatever they did was right.
This is what the Ford dealership printed me yesterday off my Ford pass. That’s exactly when I plugged in the Ez lynk in to recalibrate my tank. Been broken since January 24 and still in shop.
^^^^ Is your dealer trying to blame this on your attempt to
calibrate the BCM? If it's just a software issue it shouldn't
take Bill Gates to re-boot to factory settings, should it?
No. I am!!! I followed the instructions on how to recalibrate tank with the EZ lynk that S&B tank loans out and it took me 2 minutes or less than my truck had no throttle since. Maybe a coincidence that my truck was going to break at that time but I strongly doubt it.
A lotta happy S&B owners out there.
My money is on a coincidence. My money is also on a high level of
incompetence at your dealer if they can't suss this in a timely manner.
Good luck!
The issue is if the EZ Lynk was corrupted then you don't know what was changed, and the "as built" website theoretically has the factory settings, but those can get updated if the truck does an OTA update and the as built website takes the new changes.
It's a shame S&B and EZ Lynk are pointing fingers at each other. You still have the EZ Lynk, right? There should be a way for them to figure out what was on it and maybe even figure out what it tried to do.
The problem is when changing things if an error occurs you may not know what got changed and the error could make changes anywhere to anything.
This is why it is recommended to backup all as-built files before making changes and to use a wired usb obd adapter and not a Bluetooth or WiFi adapter. Even with a wired adapter you could have an error occur and not know what went wrong and have to restore as-builts one by one until it’s fixed.
Unless Ford has the original as-builts as the truck shipped saved somewhere other than the website the only solution might be to get them from another equivalent truck.
Just cancelled my tank order through stage3 and reordered directly from S&B. Stage3 was a month out and S&B will ship immediately. Not sure why I didn’t do this the first time.
I installed my tank and drove my truck for about two weeks before I received the ez lynk from S&B. I recalibrated the tank size which took about 2 minutes and they went to leave and discovered no throttle. It was that easy to shit wreck my King 🤮🤮🤮🤮.
Unfortunately I shipped it back and tried calling S&B to get it back but they said it’s off to another customer. WOW I said. My theory is that the ez lynk got corrupted by the last user trying to put a tune in his truck with the borrowed ez lynk from S&B and now it my problem. I’m sick. Going on week 7 without my King 👑 🤮🤮🤮. My have to phone a friend soon.
Good luck!
Nothing against the tank. I installed it myself with some help from my son. Took about 3 hours or less. Didn’t time it. Drove it for a few weeks before I plugged in that borrowed ez lynk from S&B.
Finally got a call from the dealership today and said the pcm is fried. Need a new one and $1700 it’s going to be fixed I pray. Not covered under warranty either because it’s not a Ford program that I used to try n recalibrate tank size.
I’d bring that to S&Bs attention. That’s messed up
