Rear bed camera at speed
Ok got it-
On the 7D0 01 01 is has
A081 0802 B9BD
For the 03 it has
0001 0020 00FC
Thanks @Birdhunter39 I have info from @VigilTremor as well. I have a good idea what to try but am going to compare with a few more vehicles today for consistency.
The one thing I have noticed with this on mine, keep in mind my Sync is 3.x, that certain versions of Sync disabled this feature for some stupid reason and then it was re-enabled in a subsequent version.
When I "upgraded" to a new craptastic version of Sync that disabled my bed camera access going down the road I simply reverted to the previous version that had it working.
I would expect that the Sync would enable/disable via the BCM so in theory Forscan should be able to correct this. However, since I don't have Sync 4.x I cannot say for sure and I've not experimented with Forscan to try and find the control line for this, yet.
@Modman, if you need somebody to experiment with let me know and I'll be happy to try things on mine too.
What I have found thus far is that in this address for the 22MY Trucks:
APIM 7D0-01-03 xxxx xxxx x*--
Those that can do it have the "*" as a "1" and those that can't have a "0." The feature is for "Bed Camera" and there are others for "CHMSL Camera" so maybe the term "Bed Camera" is used for the at-speed designation.
Curious what you have @MT N8IV
Good deal. I will jump on and look at what mine says and let you know.
Once we can verify on Sync 3.x what controls that I will downgrade back to a version of Sync that disables it and see if there is a difference such as turning the option back to a 0 or even shrinking the field altogether. I have found that to be the case for a few other fields/options. I expect that when this happens, it is not an intended function but rather a bug or mis-write in the Sync code.
@Modman In my previous post I mentioned the BCM... that was a mistake, and your post made me realize that. APIM would be the one, particularly with Sync.
Thanks for trying this @MT N8IV appreciate the willingness and the knowledge of your previous experience!
I thought about trying it on my truck but since I have the extra content it might lead to a "false positive." I would rather just confirm on an applicable vehicle and be sure.
Hi Modman,
Thanks for all the great help you provide to the forum!
I don't have the extra camera content, and my bed camera will not come on while driving... If you are interested, I can get you my VIN, and even let you you experiment on the truck (I don't have ForScan yet).
Here is another thread on the subject that extends into the 22MY:
Fifth wheel prep, pro trailer b'up (which comes with 360 cameras) seem to have the ability while driving.
OMG!! Researching the same option here and we pulled the 5th wheel prep off my truck due to commodity constraints. I paid MORE for them to install a B&W after the fact, but sounds like I got screwed on the camera stuff. This is infuriating!!
I pulled it off mine also and had the Ford puck system installed post factory. My bed camera works at speed. Pulled by fifth wheel yesterday and had the camera on the entire time.
I don’t have 5th wheel prep and my bed camera works just fine at speed
I have 5th wheel prep and 360 camera and it would not come on while driving. I did the modification for cameras in motion to make it work. Having the side cameras come up when you turn the turn signal on when towing is also really nice, but I turn it off when not towing.
I think that mod isn’t yet ready for the ‘22s - did I read that correctly?
