QUESTION ON NO FUEL PRESSURE DEF IN FUEL?
Whether this is vandalism or not, locking caps are a MUST! Plus I believe it can prevent accidents, as it will trigger your thought process if your not paying attention. I already have mine!
So there are some tell-tale signs of DEF in the Fuel tank beyond just a claim of "The fuel was tested". For example, you can pull the Water Separator and Drain it, let it dry-out and look for white crystals to form within the body of separator enclosure. Also, you can pull the fuel filter in the engine compartment (three fuel hoses going to / from it). Drain the fuel from it in a into a small container and let it dry out. Again look for DEF crystals to form on the filter openings.
DEF is heavier than diesel, it will settle to the bottom of the Fuel tank right away (or just about any fuel sample as DEF is 65% water 35% Urea, so it is denser / heavier than diesel) This creates a problem in that it is picked-up right away by the "in-tank" fuel pump (or any bottom fed fuel pump / fuel transfer system). Once the "in-tank" fuel pumps cycles-on (regardless of whether the engine was started) it will circulate fuel in the fuel system (to the front engine components, fuel rail, etc. and then back to the tank). Once any contaminated fuel hits the High Pressure Fuel Rail, CP4, Injectors, etc., it's pretty much over.
Unfortunately, diesel fuel contamination is a real warranty killer by Ford. And to kick a dead-horse even more, they have a "Fuel Contamination Repair Kit" that runs about $4700 (see image below) for parts that includes the CP4 fuel pump, the high pressure fuel rail and fuel lines in the Engine Compartment, 8 new high pressure fuel injectors and few other miscellaneous parts. Its the labor that's the killer on top of that (figure no less than $8k). And to make things worse, Ford voids the 100,000mi engine warranty after that (from what I have heard).
Attached is Ford's "Diesel Fuel Contamination Diagnosis" flow chart that might be helpful. The good thing is, if per what you say, "You knowledgeably did nothing wrong", then its best to take it up with your insurance company as potentially as a vandalism issue (comprehensive coverage) or a fuel station issue (knowledgeable harm by others). Many insurance companies will get to the root cause of the issue (for example request / obtain fuel samples from the last fuel station you went to, e.g., show you have receipts from fuel purchase date / time, and perhaps even go buy another gallon or so in a clean, new fuel can to show the condition still exists). From what I've been told, the "comprehensive/collision" claim on this matter is no different than if you were "at fault" or involved in a single car accident. I hear a lot of dealerships deal with 2 or 3 cases a week on fuel contamination issues.
I recently saw a Ford Ambulance that had the DEF filler cap behind the rear wheel and the diesel fill cap in front of the rear wheel. I kind of liked the idea of separation as someone above indicated some diesel (sedan type) vehicles have the DEF filler in the engine compartment.
Good Luck.
Since I got a fuel sample I pulled during the draining process, I'm going to splash it with a small amount of DEF to see what happens for myself.
Not because I'm not believing anyone here, it's for myself and gaining the knowledge.
I hear these types of stories all the time and it has made me fill up at only certain stations (typically Costco), use hotshots EDT every fill up and change filters religiously.
Honestly I don't know if it actually helps, more so for piece of mind.
If I were you, I would request the truck to be towed to a different dealership to have a 2nd opinion.
this is a good lab to get the fuel tested, best to get 3rd party review
Spot on Brother!
Still extremely happy with my BEM caps.
