Question about front springs
Advice for my 2022 F350 Platinum 6.7PS Tremor, my front springs are 5200#. When I do a new front winch bumper and winch install, should I replace my factory springs with 5600# springs if I am not lifting my truck with after market front and rear options? I have stock or near-stock sized tires...
5600 springs won't fix much sag to be honest (same spring length as 5200). The RC sku: 9285 springs fixed mine completely while maintaining the slight rake I wanted.
Does anyone know for a fact if the tremor 5200 and 5600 springs have the same unloaded length?
Fords part website is saying both of them are 20.75” and people on other forums are saying the 5200’s are 20.75” and the 5600’s are 20.25”. I just want to confirm what the actually sizes are before I go ahead and order the 5600’s.
I would suspect the 5200's and 5600's to sit at the same height once installed. I'd suspect the 5200's to ride better with a little more suspension movement. The 5600's would have a firmer ride in the end. So if you want to load the front of the truck I'd sat just get the 5600's.
  • Like
Reactions: P-T
I would suspect they would be the same height at their respective rated loads. I would also suspect that the spring rate would be roughly proportional to the rated load. If both of these are true, then the free length would be the same. At any given load, the 5600s should be slightly taller.
