Given you location : What's the general process??
Even in the USA there's a "legal" process and then there's we just make it work without any real legality to it. Meaning.....we just swap in the higher rated springs to be done.
Legally in the USA it becomes a bit of a task to get the rating changed on paper. It's VERY different to get them to change the actual door sticker numbers. It can be done, just not the typical thing done even in the USA.
There are accredited engineers in each state. These engineers work within certain parameters. You pay an engineer to certify that the modifications are safe and legal. Different engineers will have their own way of arriving at a decision.
Take GVM upgrades for say the Ranger. If it’s a known kit from a known, acceptable manufacturer, then they just check all the right bits are there, as it’s all been done before.
One offs like mine is where it gets difficult. Some want to brake tests fully loaded to the higher weight. If there is a factory option though, and all the parts from the factory option are present, it should be much easier. Those associated parts will include front axle, brakes, hubs, bearings, wheels and tyres.
I spoke to the people I brought the car from. They hold second stage manufacturer status. They certified the car complies with all the Australian Design Rules (ADR’s). On my rego certificate, the manufacturer isn’t Ford, it’s VDC Ford, with VDzc being the company who I bought the car from. They assured me that with non Tremors, there is no difference between trucks with the 5200 rating and the 5600 rating other than the springs.
I’m hoping that if VDC put that in writing, as the manufacturer, then the engineer will accept that and once satisfied the 5600 springs are installed, will sign off on the paper work. Then I just need to visit a motor registry, hand over the engineering approval and that’s it. They enter it into the system and the modification is noted on the rego certificate.
