ShhhhhhI believe what you mean to say is; "Project Overkill is complete, for now...."
Very cool. Well done .The last piece of the puzzle finally arrived today! Got my plates. This was the only permutation of “overkill” that was available.
Because even though I do tow with it, for the most part it’s waaay more truck than I need. And my usual payload is a 16lb bicycle..... so what makes this project "overkill"?
Because even though I do tow with it, for the most part it’s waaay more truck than I need. And my usual payload is a 16lb bicycle![]()
Hmmmm. Maybe some security screws would be appropriate. I’ll investigate and report back.Nice plate!
Food for thought...If you're using the plastic license plate holder provided by Ford it can be removed very easily by just pushing up on the plastic tabs and pulling the holder straight out. No tools needed and it takes two seconds to remove. I wouldn't want some Hobostank to steal your front plate for FasTrak use or whatever reason. I know the back is easy to remove also, but nowhere near as easy as the front.
