Thanks for the info you gents provided...Building confidence on this project. Another couple of questions - do the Morimoto accept the auto high beam function built into the truck, and second - If I tap into the up fitter switch for the outer light bar (thus by passing the fuse tap) what would be the up fitter power wire recommendation? I'm assuming I would leave these "on" on the UFP switch and activates while the ignition is on. This way I could turn them off in a campground or whatever stealth moves I might employ...looking at the truck manual - I'm thinking this is driven by amps on the UFP fuse block? One wire to/from the led light bar (cut off the fuse tap) to one wire from the UFPower wire? Already grounded as fused...Correct? Apologies for the seemly dumb questions - I just don't want to FK this up and you all know more than I.
You can definitely do that. Just connect the fuse tap wire to the upfitter of your choice instead. You can leave this on all the time and it will still run the DRLs whenever the truck is running and will still dim the DRL at night when the headlights are on. If you turn off the upfitter, it will turn off the DRL functionality for stealth mode. Very easy to do.
You can connect this to any of the upfitters, but I'd recommend doing 1-4 and save 5-6 for higher power accessories; AUX 1-4 hold 20A each and AUX 5-6 hold 40A each.
I meant as to why you don’t recommend to run DRLs?
I believe we're misunderstanding each other here.
The stock halogen headlights have a DRL function and it runs the 4 headlight bulbs at a lower power than the regular low beams. The stock halogen headlights do not have a dedicated Daytime Running Light.
When you install the Morimoto headlights, they have a dedicated LED Daytime Running Light that is separate from the low beam and high beam projectors. To power the Morimoto DRL, you will use a fuse tap and pull power from the fuse box. The Daytime Lights option in the gauge cluster does not control the Morimoto DRL, however, it will try to activate the factory DRLs which is the low and high beam projectors and it will cause the low and high beam projectors to flicker as it's not sending them full power. To avoid the flickering, you'll turn off the Daytime Lights in the truck's gauge menu, but you will retain the Morimoto DRL strips by using the dedicated fuse tap that they include.
