Power Tool purchase poll : What to do
What power tool to buy??
  • Total voters
    37
Funny thing is, I had a table saw long before I ever bought a miter saw. I did everything on that saw, including ripping, dadoing, crosscut, even finishing with a 100 tooth 10" blade. (still have it 40+ years later) It did the jobs I needed it to do at the time.
However, when I finally decided to expand the shop back then, I started adding other tools like the drill press and miter saw. I went through 3 different miter saws before getting the Dewalt 708.
Moral of the story, a table saw works for many things and the miter saw simply makes some cuts way faster and easier. I don't think you can go wrong with either one.
Made 30 years ago with only a table saw and hand tools. Solid walnut and maple slides.
No worries. In order to bring a little civility to this I offer the following. I hope this gives a good laugh :
A young family moved into a house next door to a vacant lot. One day, a construction crew came in and began building a house on the empty lot. The family's 6-year-old daughter became interested in all the activity going on next door and spent much of each day observing the workers.
Eventually, the construction crew, all of them gems-in-the-rough, more or less adopted her as a project mascot. They chatted with her, let her sit with them while they took coffee and lunch breaks, and gave her little jobs to do here and there to make her feel important.
At the end of the first week, the men presented her with a pay envelope which contained $5.00. The little girl took this home to her mother, who said all the appropriate words of admiration, and suggested that they take the money she received to the bank to start a savings account.
When they talked to the bank teller, she was equally impressed and" asked the little girl how she had earned her very own pay check at such a young age. The child proudly replied: "I worked last week with the crew building the house next door to us."
"My goodness gracious," said the teller, "and will you be working on the house again this week, too?"
The little girl replied, "I will if those assholes at Home Depot ever deliver the fuckin sheet rock..."
If just working around the house I have found harbor freight to fulfill everything I have ever needed, excellent return policy and customer support and you might be able to afford both tools as well. Can't wait for the comments on this one.
I think there is a difference between being able to do something (you can pretty much do about anything with a table saw) and being able to do something efficiently and repeatedly. Casual woodworking is fun and making jigs for a table saw or radial arm saw can be fun, but it is definitely NOT efficient. The miter saw speeds up making multiple repeatable cuts when production is a priority and you value your time. But obviously you can’t rip with it. Ripping with a circular saw isn’t bad with a good straight edge but again setup takes longer.
Someone mentioned festool. Awesome stuff but $2k for a portable table saw and $1500 for a miter saw just aren’t worth it for non professionals
Harbor freight is good for things you don’t use often. They work fine usually but the features, ergonomics, performance and overall tool life are usually lacking if you use them everyday.
The Dewalt 780 miter saw is great but not quite as smooth as a similar makita offering. It’s also almost half the price. I like the shadow line over a laser line too. The Bosch miter saw stand is definitely my favorite followed by the rigid miter saw stand. Definitely a must have unless you have a built in bench or similar.
I’ve had most of the portable table saws and I liked the Bosch and stand but burned 2 of them out. The metabo saw works ok but falls apart. The makita saw had a bad fence and was super heavy. The rigid saw was fair but the fence was a bit janky. Haven’t tried the skil saw table saw. The dewalt table saw is my favorite portable saw. Wish it had a stand like the Bosch
Apologies for not reading every post thoroughly, so this may be already covered. I have both (2 table saws, 1 mitre saw) plus a couple of circular saws and track saw.
It really depends on what you plan to cut.
The chop box is great for cutting studs and other long pieces to length. It’s easy to set up and provides a quick cut. If you are cutting studs outside, chop box all the way. But they are messy and loud. If dust is an issue for your shop, you will need to do something to manage the dust created by this machine. A vac hose attached to the dust port is just a start.
They are terrible for cutting small pieces. A table is more versatile and with careful setup, you can cut pieces in the 1 inch range. But if you are trimming studs, a table saw is dangerous (kickback). Sawhorses, a circular saw and carpenters square is a much better choice.
If you need to cut plywood and other pieces of wood and you want a straight cut, square to the other sides, you can’t beat a table saw. But handling full size sheets on a contractor saw is no fun. I break down full sheets with a circular saw or have the store do it. Square up the smaller pieces on the table saw.
If you have the room, bigger is better. The point of using a table saw is the tool is stationary and the work pieces move. If the saw is lightweight and flimsy, not well anchored…it will move around. Moving saw and moving work pieces is a very dangerous combo.
Larger saws are 220V here in the US. A 120v saw is a F-150 and the 220V saws are the Super Duty of saws. You don’t always need it, but it sure is nice to have. The bigger saw can do everything the smaller saw can do (except be mobile).
My recommendation for home use is table saw and circular saw, plus a nice set of saw horses. Get an carpenter’s square/triangle and you can get square cuts on long pieces.
I’m turning into a big fan of the battery powered tools. And get your plywood broken down at the store (they all have panel saws).
Of course, if you are an expert and have the time, all you really need is an accurate tape measure, a sharp pencil and hand saw.
Nothing wrong with Harbor Freight. They can have some decent stuff, if not even disposable at a price point.
I don't really have the space for a table saw (Home Joe or Pro version) at this time. I got a choice of circular saws along with the square or any other straight edge tool. I agree the miter saw gives the ability to repeat cuts easier/more efficiently. Given what I intend to do in the short run sounds like the miter saw is a better choice. I just wanted to hear out any ideas/suggestions about each tool. I just hate the idea of trying to rip cut a 16' deck board with a circular saw, but I'll give it a go.
If it's just one it wouldn't be too bad... Take an 8' chuck of something straight, clamp it to the deck board and make half the cut and repeat. Now, if you have to do 30 of them that's a different story... :)
At this point it's just one, next to the house at the foundation plate. That's not the only task I have at hand to get done. :unsure: :unsure: :cool::cool:
For that I would either just scribe a line on the board and eye ball it with the circ saw or use the rip fence that some circular saws come with.Screenshot_20240326_103702_Chrome.webp
Ripping 16' of 1.5" thick material would be torture with a handheld. Just buy the table saw and enjoy the nice clean cuts.
