Power running board chrome removal
Very easy to wrap the tailgate chrome strip yourself. You can get a 6" wide 5' long strip of 3M wrap off of Amazon for $12 (and have lots left for other projects).
You don't need to take the chrome strip off to wrap it. Use one of the small plastic squeegee's that you get with phone screen protectors (or a credit card) to tuck the wrap into the cracks along the edges.
I have a 2021 Lariat Tremor with the black package with the power running boards. Only three pieces of chrome on the thing. Two chrome caps on the edge of the running boards and a small strip above the tailgate release button. I read on here where someone removed the chrome caps on the power running boards. I thought I would give it a try.
Close the door and step on the running board. This will make it stop in place. Using a Phillips head screwdriver there are two screws on each end holding the end caps on. One pointing down and one pointing to the inside of the truck. Once those are out the caps just slide off the end. You will see the chrome cap is a very thin piece of metal. Other than the caps holding the end of them they are held onto the running boards with double stick tape. Grab the end of the chrome strip with some vice grips. Pull down and out at about a 45 degree angle. They will come right off. On one side I had maybe a total of 6 inches of double stick tape stay on the running board. On the other side all the tape stuck to the chrome strip. A little finger rubbing gets the tape off as it just balls up. When done stick the caps back on and enjoy.
Super easy modification that I wish I had done on day 1. Now if I can only get that piece on the tailgate handle.
Planning on this "MOD" when my rig comes in! Thanx!
Liked the post on how the stock boards offer protection in parking lots... Door Dinging is an Olympic sport out here in nutty California, not to mention most parking spaces are just big enough to fit a mini cooper. Very maddening. Plus I like the look of the stock boards.
I assume I do the reverse to put the chrome strip back on the running boards if I want.
I had my chrome wrapped a few months ago and decided to remove the chrome today. I like to do it the most expensive way. I like it a lot.
I lower my power running boards in parking lots. You can either step on them when closing the door and they will stay down, or you can lower them in the vehicle option screen. I fold in my mirrors and lower my running boards to protect the doors. Seems to work pretty well.
Thinking I may remove mine this weekend. I have the Star White and all black would look alot better.
Is there some kind of adhesive on the back that doesn’t allow you to slide these pieces out? I’m wanting to keep mine intact but wrap them and slide it back in. If that’s even possible.
Correct. It's a pretty strong adhesive that takes a pair of vice grips to pull off. Unfortunately, once you peel it off, it's not reusable with the deformity it takes.
So you waisted money on the wrap then removed the chrome anyways 🤔
Yep. Didn't cost much to wrap them and it was bubbling around the edges. Much better to remove the chrome. Hopefully my experience helps some members.
Lol...they will need a little straightening first. Mine were recycled...lol
bringing this old one up.
when removing the chrome, do the edges, or can the edges gouge up the surface underneath?
i did this on my chevy power steps and the edge of the chrome left a few gouge marks.
thanks
thanks
No, it’s just adhesive on the backside. Start an edged and use some pliers to try to take it off in one strip. ‘20-22 anyways. Not sure if ‘23 up are the same.
I removed mine intact with the help of a heat gun and a long screwdriver. I took a little time, but I wanted to preserve them in case I didn't like the look and wanted to wrap them and put them back on. I still have them in the garage and will not be reinstalling them.
