Platinum stock 20s not fitting tremor on rear
How can this be? Arn't all four wheels the same? With your Tremor, the front and rear wheels are the same so the hub diameters must be the same.
As Tex_Hunter mentioned earlier in the thread, it's the hub/flange on the rear Dana that sticks out further than the Sterling. The front hubs don't stick out as far, so no wheel fitment issue.
You might notice that the center caps are different depths on Super Duty's with different rear axles. Sterling 10.5 uses the shallowest cap, and from what I hear, the new Sterling 11.6 uses the deepest cap. Deeper than the Dana.
OP said the wheels were off a 2019 MY truck.
Since there were two different axles on F250 trucks in the past. One was a standard, the other an upgrade. The upgrade was the same axle as on the SRW F350 trucks. The hub bore was different, hence "two" different wheels for some F250 trucks.
I want to say the hub bore is 125.1mm. So use the front axle as the primary measurement, with the rear axles potentially being two different sizes for older trucks.
Hub bore size is and has been the same 250/350, no matter what axle.
If the OP had purchased one of the OEM wheels with removable center caps he wouldn't be having this issue. The wheels would have fit and he would just need the correct depth of center cap. Point is, that wheel was only made to fit a Super Duty with 10.5 Sterling rear axle. It will not fit a Super Duty of any year with a rear axle other than Sterling 10.5.
Up until reading this thread I had thought that all Super Duty 18" wheels from when they were introduces in 2005 to present were all dimensionally the same and interchangeable. I know this thread is about a particular 20" wheel, but it brings up differing hub diameters. I had thought they were all the same. I just now pulled a rear wheel off of my 2024 Tremor with a Sterling 11.6". I then tried a wheel off of my 2006 F-350 Lariat with a Sterling 10.5" and it fits fine, same center diameter. Then I tried a wheel off of a 2022 Tremor with a Dana M275, and it also fits with the same center diameter. So there are examples of the three different rear end designs that I know of being used in SRW Super Duties, and all have the same center diameter. I never knew there were some 250s with something smaller.
BTW, I think the center is 124mm, not 125mm as mentioned here and elsewhere. I do not have a way where I am now to measure accurately, but it looks closer to 124 than 125. I could be wrong though.
Not sure if the thickness varies, but the hub sticks out further on the M275 than the Sterling did. I had the Fuel wheels swapped from my '15 F-250 Platinum over to my '22 F-250 Platinum Tremor at the dealership when I bought it. I didn't notice it until I got home, but the removeable center of my center cap would not sit down flush due to the longer hub. I made a post with pics on what I did to correct the issue. https://www.fordtremor.com/threads/issue-and-solution-with-fuel-wheels.16805/
Are you saying that the front and rear wheels were not interchangeable on these trucks and that the tires could not be rotated? I find that hard to believe.
Back in San Diego I have a set of 2022 Tremor wheels and a dial bore gauge. I will make an accurate measurement when I am there.
You are correct, or at least more correct than I was. I just measured the bore of a 2022 Tremor wheel and got 4.929 which is just under 125.2mm.
What were you incorrect about, and what significance is the bore diameter? All the OEM Super Duty wheels have the same bore diameter going way back.
I commented that it looked closer to 124mm than 125mm, that is all. I was wrong on that. It is on the high side of 125mm. We are down into the sub millimeter stuff now. I agree that they are all the same going back at least to 2005, and maybe before that.
