I had an issue with my rear Fuel wheels after swapping them over to my new truck. Due to the Tremor having a slightly longer hub, the center cap wouldn’t sit flush without popping the center of the cap out. You can see the gap in the pic of the cap. Forgot to take a pic of it on the truck. I spoke to someone with Fuel and they recommended the spacers in the pics. After installing the spacer, the center cap stuck out past the outer edge of the rim and looked horrible! I cut about 1 1/2” off with an. angle grinder and then used sandpaper to get a nice finish so it would sit flush. There was already a lip on the bottom that I used as a guide so I wouldn’t cut too far down. It turned out perfect, and you can hardly tell a difference.
