Featured
- #101
@Optimus🤖 has it right, you can hook minor draws to the chassis anywhere. Minor draws would be like lights (withing reason) and just about anything else. If you are running a high current device, say more than 30 amps, (compressors) hook to the battery. The interconnect wires for the panels from the aluminum to the chassis are relatively small and an accumulation of devices can tax the cable size.
If it were me hooking this up, I would run it to the battery post since I don't know what the total current would be for all of the upfitters running at the same time. Not that anyone would do that, but it's a safe place for multiple unknown accessories that draw a lot of current. When you have multiple accessories, the total current of all upfitters will be flowing through that one ground wire. Now add in the smallish wire from the panels where the ground is attached to the battery, connected in series with the existing chassis interconnect wire, and hopefully all accessories added up does not compromise the size of that wire. Most people would never know any difference because the odds of all the upfitters on and all drawing a lot of current, is not likely.
Hope this helps.
To piggy back here, when I did car audio back in the day, I typically ran power and ground from the battery to the back cab or trunk with each leg being on its own distribution block for other devices to tap into. Left no uncertainty of good connection and removed ground loops
