I take my old oil and filters to the local Autozone. The local dump also has a chemical drop off and the garbage service also offers some kind of curb side pick up option at no cost.May I ask what we're doing with the old oil
This is my current path.I'm looking to do my first oil change soon. Is going right to synthetic recommended or should I go to a blend first then do another oil change and go full synthetic.
Thanks I'll have to check my auto zoneI take my old oil and filters to the local Autozone. The local dump also has a chemical drop off and the garbage service also offers some kind of curb side pick up option at no cost.
To emphasize what @DrEvil noted above, it's not just AutoZone. Napa and O'Reilly's also take used oil for free (up to a maximum amount).Thanks I'll have to check my auto zone
that's what i run. i'm out here in az.What does everyone think about 15w40 (motorcraft). It’s an approved viscosity, but I don’t really see anyone using it.
Thoughts?
Fine for hot climates but for states with cold weather half the year better off with 10-30 or 5-40 personally I run 5-40 full syntheticthat's what i run. i'm out here in az.
So fun fact, does not work in diesel. I was commonly doing this in my Ecoboost for similar reason and mostly cam phasers.This is my current path.
First change was with the Ford blend, from then on will be full synthetic and Blackstone analysis at each change.
My truck sits a lot, so I mash the accelerator and spin the engine over for two start attempts to build oil pressure before starting.
Most of this is picking nits, though peace of mind is exactly that…
It's fine, generally speaking. Some like to do an early change (~1000mi) but it really isn't necessary. I tend to stick with 5k intervals on my vehicles. The oil minder algorithm will use cumulative engine cycles, engine load, and time. If you hit the time limit it will tell you to change the oil regardless of the mileage. If you tend to be lightly loaded all the time and accumulate mileage quickly (read: lots of highway) going by the minder is no issue. My preference is to control the changes on a more regular basis, though.Would it be fine to wait until the truck (7.3) says to change the oil or do it early?
| 7,891 (28,212) | 9381 (20,321) | 5343 (10,940) |
| Triax 5w/40 | FoMoCo Conv 10/30 | FoMoCo Conv 10/30 |
Here is my used oil analysis from Blackstone Lab. The oil during this OCI was Triax Fleet Supreme 5w/40 and FoMoCo Filter. I paid the extra money for TBN (Longevity usage) and Soot Levels. Extended or Long oil change intervals are superflous if you are having you system chewed up or clogged up by fine particles such as soot. Maintenance minder was at 0%....
For Clarifaction
7,891 (28,212) 9381 (20,321) 5343 (10,940) Triax 54/40 FoMoCo Syn Blend FoMoCo Syn Blend
10/30 according to my service receipts. The synblend came from the service advisor so I will be honest I did not know that. I will update my original post.FoMoCo doesn't make a synthetic blend in a diesel oil for the 6.7l, just conventional and full synthetic. What was the viscosity of those FoMoCo oils?
My last 4 have been 66,67,68 and 67.FoMoCo doesn't make a synthetic blend in a diesel oil for the 6.7l, just conventional and full synthetic. What was the viscosity of those FoMoCo oils?
