That makes senselots of idling and slow city driving.
Utah Powder,Hi -
Instead of doing the oil change myself, the dealer charges $30 if I supply the oil making it pretty painless. Then pay with your Ford pass points that they do it for "free" many times over. Rotella T6 is what I use. You can reset oil interval, instructions in the manual.
Oil water separator is under the truck basically behind the second row doors... lots of videos on it. The challenge is disposing of the fuel that come out in a proper manner if you don't have a bonfire to start.
Garff American forkUtah Powder,
Mind if I ask what dealer does that for you? I bought my truck out of State ( I live in Utah as well) and would like to do the same thing. I dont really have a dealer I would say I am 100% comfy with. That sounds like a great way to do it.
How are you liking your air filter? I’ve been debating between yours and the spe.I change mine (Full SYN Rotella t6) every 5K miles.....I drain the water seperator every 5K miles.....and I treat every Tank of gas (and Oil) with the appropriate Archoil product. Changed fuel filters at 15K. Use Motorcraft Filters except for the air filter. I switched to a permanent dry cleanable filter.
Magnum FLOW OE Replacement Air Filter w/ Pro 5R Media
Pro 5R Filter Media:This filter features five layers of pre-oiled cotton gauze media to provide maximum performance. Its progressive layering allows the filter to flow at high levels even when dirty. This media is perfect for street and/or track use. Pro 5R filters are easily recharged with...afepower.com
One last note: 24Hours and about 40 miles after my last oil change, my oil was black as coal!
Seems to work good.....Have not cleaned it yet......It also has not caused my check engine light to come on, thank god.......How are you liking your air filter? I’ve been debating between yours and the spe.
it’s based on your driving habits. Short drives, idling, etc impact it. if you did longer commutes and more highway it would be a lot higher.My 22' 6.7 OCI calculator is showing only around 4700 miles after my recent change, which seems low to me.
I drive a 20 mile round trip each morning, about half highway and half city (no towing). Oil gets up to temp about halfway through the trip.
I'm using Amsoil, so suspect I could go longer if I wanted.
Any idea why such the short OCI?
Yes I use the Amsoil signature in 5-40 and the EA filters. Been using Amsoil for 35 years in all of my oil burners. I change when the truck tells me to. Most of mine is highway and when I do get to the ranch sometimes in the summer the truck will not be shut off for 6 or 8 hours.at 15%, getting ready to do mine
You can go in and reset the oil minder yourself through the gauge cluster menu.Hoping for some oil change advice from someone with similar situation.
I bought my Tremor in March of '21. Here it is two years and two months later and it has 7,800 miles on it. The first oil change was done last year at the dealership at about 5,000 miles. The dashboard is now telling me to change the oil. The oil is old age-wise, but not old, mileage-wise. Is there a way to just re-set this thing without changing oil? I'd like to get a few thousand more miles out of this still-good oil.
What does everyone think about 15w40 (motorcraft). It’s an approved viscosity, but I don’t really see anyone using it.
Thoughts?
May I ask what we're doing with the old oilI should have added that I do my own oil changes (I am not saving money doing it my self, I'm saving time)
I bought a case of Motorcraft filters from dieselfiltersonline.com, I have about $11.00 a piece into them.
I try to run 5w40 Rotella T6 (which is full synthetic) if I can find it - it is currently unavailable but it ranges from $25-$30 a gallon
So I end up having $85-$100 an oil change into it. It takes me about a half hour and I am able to give everything under the truck a look over, grease my 2 grease fittings (axle joints), I also drain the water separator every oil change - DO NOT OVER LOOK THIS.
