Featured
- #321
Or maybe security Torx (with the pin in the center).I can also utilize Torx button head screws for the light portion instead of just regular hex/allen key button heads.
Yes, that’s what I mean. I’d have to supply a bit though or an L wrench.Or maybe security Torx (with the pin in the center).
No rust as they're stainless.potential for rust.
You need the Limitless spotlight override adapter still (or the other guy that makes it). I have it on my truck with my ditch lights.
No they didn't.. I can assure you that you'd find out quickly when it happensSorry I may have missed, but did preorders ever go live?
I have a lead on the actual connectors to use. Need to get the terminals in to confirm but if this works... for $15-20 (including shipping), crimping some wires and trimming a lil plastic on the purchased female connector... a guy could make his own.You need the Limitless spotlight override adapter still (or the other guy that makes it). I have it on my truck with my ditch lights.
I think this is awesome but i feel like my wallet is going to hold a SERIOUS grudge.I have a devised a way of retaining the hex nut to prevent theft.
There won't be an acorn nut now, however, but the S2 light bracket will be pre-installed at our facility. The Fuji spring lock hex nut (hopefully black color) will be fastened, and then we will Tig tack weld the last thread on the stud to prevent the nut from coming off. There will be enough threads to loosen and tighten the nut still for adjusting the light where you want.
This, in addition to the security Torx button heads will be as good as it gets.
Got the terminals in today and not sure i got the female ones correct. The terminal sticks to far out the back even when seated that touching is a concern. I made one and before i figured out how much to trim off the green stock connector, i accidentally pulled a wire out of a female terminal. So...I have a lead on the actual connectors to use. Need to get the terminals in to confirm but if this works... for $15-20 (including shipping), crimping some wires and trimming a lil plastic on the purchased female connector... a guy could make his own.
i'll share the p/n's once I nail everything down.
Could one possibly order additional front hardware when purchasing this kit if they were interested in making their other BD lights match?Pics of the new hardware!
Not something I planned on for price costing. I'm spread pretty thinly across many products. You can order the same matching hardware from BelMetric.Could one possibly order additional front hardware when purchasing this kit if they were interested in making their other BD lights match?
