Featured
- #241
- Jul 29, 2023
- 4,079
- 11,922
- 2023 F350 XLT Premium Tremor, SAP, 7.3L
- 2027 Toyota Landcruiser 1958.
All the Tremorites in this thread.
It would be a beta unit and would be very expensive, or I would take my pre-production ones off my truck and let you use them. Definitely possible if you want it though. If I get at least 100 people to order, everyone will benefit. Machining in volume is much less expensive.how much to get this before July? Still haven’t opened the light bar box
So stoked for these! Just installed your tank warden and LOVE IT! So well designed and thought out.Finally mounted! Preliminary light bracket is vibratory tumbled aluminum. Final should be black.
Car wash testing and high speed driving test begins tomorrow, to make sure there's no whistling noises.
Thank you!So stoked for these! Just installed your tank warden and LOVE IT! So well designed and thought out.
Wow! What a difference!!!!!!Here's a quick video showing how the ditch light fills in the side area with the headlights on.
Turned the ditch light on and off a few times in the video for demonstrating how effective the additional lighting can be.
Great work! Those brackets turned out really nice.
The wires attach inside the trim panel to the wires that go to pins 15 and 22 (for the spotlight).These look good. Can’t wait to see the final results. I’m curious how you have them wired to work with the mirror spot lights.
I can see these being extremely useful and used quite a bit.
No worries about drawing too much from stock wires?The wires attach inside the trim panel to the wires that go to pins 15 and 22 (for the spotlight).
No worries. As mentioned early on in thread, that electrical testing was completed almost 2 years ago.No worries about drawing too much from stock wires?
This is awesome! Any chance we could get a view out the drivers window aimed at sort of 10:00 like your making a turn off road? Curious if your setup could get similar coverage without having to turn it so much that you’d give up the forward coverage your pics above are showing (Example from my old setup below, that was a Rigid SR-L mounted on the side of my old Ranch Hand bumper)
I can't believe you've been working on this in the forum for 2 years and I'm just seeing it now! This is an idea that I had a few years back, but I wasn't smart enough to capitalize on itFinally mounted! Preliminary light bracket is vibratory tumbled aluminum. Final should be black.
